19wolf
January 7, 2021, 11:27pm
22
If you look at one of my earlier posts, you’ll see that config.yaml hasn’t been touched since October. Additionally, when I look at it, almost everything is commented out/default. I’m guessing it was created initially by the docker container and I never touched it.
When I mv revocations.db revocations.db.old it looks like revocations.db is NOT recreated. I’m going to try again after chmod -R 777 per mus6677’s suggestion.
update: no change
Can you try to just run docker without using compose and see if it works?
Alexey
January 8, 2021, 8:03am
24
The owner of the mount point is media, but all folders and data has root as owner. You either should change owner to the media and configure docker to run without sudo, or use sudo to start node.
Please, also rename or remove the config.yaml file, add to your environment: section of docker-compose.yaml the variable SETUP=true, start node once, it should exit immediately. Then remove this variable and try to start again.
19wolf
January 8, 2021, 11:42pm
25
No change. Still getting the disk I/O error: no such device – the new config.yaml file was created as -rw------- owned by root
This is strange. Your old and new disks at the /data mount point are just hard drives or something more complex?
19wolf
January 9, 2021, 12:03pm
27
Old was a lizardfs configuration on the single node, comprised of four local chunkservers, one for each disk
New is the same four drives now using mergerfs to combine them. The filesystem on the drives is xfs
Alexey
28
Please, show result of the command
$ df -HT
19wolf
January 9, 2021, 12:04pm
29
~$ df -HT
Filesystem Type Size Used Avail Use% Mounted on
udev devtmpfs 6.3G 0 6.3G 0% /dev
tmpfs tmpfs 1.3G 9.2M 1.3G 1% /run
/dev/sda2 btrfs 1.1T 208G 775G 22% /
tmpfs tmpfs 6.3G 8.5M 6.3G 1% /dev/shm
tmpfs tmpfs 5.3M 4.1k 5.3M 1% /run/lock
tmpfs tmpfs 6.3G 0 6.3G 0% /sys/fs/cgroup
/dev/loop1 squashfs 16M 16M 0 100% /snap/ponysay/73
/dev/loop2 squashfs 16M 16M 0 100% /snap/ponysay/79
/dev/loop3 squashfs 103M 103M 0 100% /snap/core/10577
/dev/loop4 squashfs 59M 59M 0 100% /snap/core18/1932
/dev/loop0 squashfs 59M 59M 0 100% /snap/core18/1944
/dev/loop5 squashfs 65M 65M 0 100% /snap/core20/875
/dev/loop6 squashfs 65M 65M 0 100% /snap/core20/904
/dev/sdb xfs 10T 5.4T 4.7T 54% /mnt/data-2
/dev/sdc xfs 12T 6.7T 5.4T 56% /mnt/data-3
/dev/sde xfs 14T 7.9T 6.2T 56% /mnt/data-1
/dev/sdd xfs 12T 6.6T 5.5T 55% /mnt/data-4
tmpfs tmpfs 1.3G 0 1.3G 0% /run/user/1000
/dev/loop8 squashfs 132k 132k 0 100% /snap/lolcat-c/1
1:2:3:4 fuse.mergerfs 48T 27T 22T 56% /data
/dev/loop9 squashfs 103M 103M 0 100% /snap/core/10583
Alexey
January 9, 2021, 12:14pm
30
Try to check your mount (if you use sudo to run docker-compose, then run following command with sudo too):
docker run -it --rm --entrypoint sh --mount type=bind,source=/data,destination=/app/config storjlabs/storagenode
when you see a prompt
echo "test" > /app/config/storage/test.txt
cat /app/config/storage/test.txt
rm /app/config/storage/test.txt
Please, post results
This is simple on mobile too - add a new line with three backticks ``` before the code block and new line with three backticks after the code block. I edited your post to show an example.
19wolf
January 9, 2021, 12:26pm
31
sudo docker run -it --rm --entrypoint sh --mount type=bind,source=/data,destination=/app/config storjlabs/storagenode
/app # echo "test" > /app/config/storage/test.txt
sh: can't create /app/config/storage/test.txt: nonexistent directory
edit: My data is at /data/Storj not /data, and when I fixed that it worked fine.
Alexey
January 9, 2021, 12:41pm
32
honestly I do not like it. However it’s your choice to accept a high disqualification risk.
And I’m afraid that SQLite do not like it too.
Please, check all databases with this guide:
FWIW, I was unable to use mergerFS for Storj in a quick test a while back, although I use it regularly for other bulk data.
It’s likely to do with the Sqlite issue that impacts other apps like Radarr/Sonarr. See this FAQ at the Servarr wiki :
If you are using mergerFS you need to remove direct_io as sqlite uses mmap which isn’t supported by direct_io as explained in the mergerFS docs here
Consider trying it with the dbs and orders directories to a dedicated “app data” location, or just use single disk filesystems for your Storj node.
