Monitoring payouts after node exit
Hello, I started exiting nodes about a month ago. I did check today, and some are already showing exit status Successful: Y, with exit receipts. I need to delete the data as I’m selling the drives, but I would like to keep the nodes running, so I can verify the held amount has been returned.
Is it possible to delete just the data directories (with keeping the databases in place) and keep these exited nodes running? If so, will they still receive payout receipts?
Thank you.
I don’t understand. Are your databases on different drives to the data?
Are you thinking that you need to get on with deleting the data so that you’ll be ready to go when the held amount is paid?
A format would probably be far quicker way to delete the data drives.
I have no idea about your question though, sorry. :slight_smile:
Data is on hard drives and databases are on SSDs. I can keep the databases, at least for now, but the data has to go.
However, I would like to confirm whether the held amount has been paid. Since I use the same wallet for everything, and because of the mess with the prepayments (some nodes getting more, some less, and some not getting paid at all because they are less than 15 months old - or at least this was the case with the last payment), it would be practically impossible to track whether the held amount was paid, and whether it was paid in full.
That is the reason I would like to keep the nodes running, as they do track the payouts per node.
Also, by “deleting the data” I mean unmounting the data directory rather than actually deleting the data. I just need to remove the drives from the system.
There could be a problem with the prepayment, because the prepayment is calculated for active nodes only (exiting, offline, DQ are excluded).
However, the previous Undistributed should be paid. So, there could be a delay for a month.
@elek please confirm
