I moved my drive from a raspberry pi to a linux server, where I have two other nodes running. I did the migration process as described in the docs, minus the rsync part since I simply moved the drive and identity files over.
When I start it back up though I’m getting this error… help!
2020-07-21T15:40:19.922Z INFO db.migration Database Version {“version”: 39}
Error: Error during preflight check for storagenode databases: storage node preflight database error: reputation: expected schema does not match actual: &dbschema.Schema{
Tables: *dbschema.Table{
Columns: *dbschema.Column{
… // 5 identical elements
&{Name: “audit_unknown_reputation_alpha”, Type: “REAL”},
&{Name: “audit_unknown_reputation_beta”, Type: “REAL”},
Based on this thread, it’s looking like my reputation database is what’s messed up, but I don’t want to risk trying anything in this thread until I know if that’s really the issue… so help would be appreciated, thanks!!!
Have you double (or triple) checked that you are not reusing/duplicating paths between your migrated node and existing nodes. Also check that the node software version that was on your raspberry pi is the same as the node version on the linux server?
Definitely checked paths in the docker run statement, they look right.
Somehow in the process of shutting down my Pi and moving the drive, I messed it up and now I can’t get the Pi to boot properly… so I can’t get the version it was running.
But I was running Watchtower, and I’m pretty sure everything was the latest version. So I wouldn’t think that the new server is running a different version.
Try setting the owner to admin and group to root. That is how it appears on my drive. New db’s created by the node as they have been added to the software seem to set the group to root (as it appears happened with two of your dbs).
I think that would only be a problem if you migrate a newer version node into an older version (i.e. your linux server is out of date). If the raspberry node was out of date, it should have updated dbs on your linux version as soon as you started it. Did you do a fresh pull of the container image from docker before starting the migrated node?
At this point I would also run fsck on the migrated disk to check for errors. That’s about all I can think of for now. Good luck!
That message suggests that the image you just pulled was newer than what docker had in it’s cache. I would try rm’ing and recreating the container for the migrated node now that the newer image has been downloaded.
Before Step 9, add a step to run a pull to make sure you have the latest version of the container before you do the Docker Run command on the new machine!!!
Glad we got it sorted! The devil is always in the details. I’m curious, do you have watchtower running on the linux server? I would have also expected that if watchtower is running, the latest image would be in the cache. But perhaps it doesn’t work that way with watchtower.
