You should use your external ip not local ip
about directory i am not mac user, hope storj team can help
It should be
/storagenode",destination=/app/identity
by removing the / at the end of the path.
Post your updated docker command after you enter your external IP & remove / from the identity path
it is now online i replaced it with the ipv4 adress and it worked !
Thank you so much Vadim !
