Not sure what happened but my node: 1MhTUzg1fzdoZBAU1MNveQq1WpL7FyfQ3X5MDKBxsuXHUaJrba was causing a memory leak and ate up all available memory, thus terminating services. Had to stop it and restart the node.
It is not a network drive. I PWD into the database directory and tried to run the docker command. Also tried replacing ${PWD} with direct path, error below.
ash-4.3# docker run --rm -it --mount type=bind,source=${PWD},destination=/data sstc/sqlite3 find . -iname *.db -maxdepth 1 -print0 -exec sqlite3 '{}' 'PRAGMA INTEGRITY_CHECK;' ';'
find: unrecognized: heldamount.db
BusyBox v1.31.1 () multi-call binary.
Usage: find [-HL] [PATH]... [OPTIONS] [ACTIONS]
Search for files and perform actions on them.
First failed action stops processing of current file.
Defaults: PATH is current directory, action is '-print'
-L,-follow Follow symlinks
-H ...on command line only
-xdev Don't descend directories on other filesystems
-maxdepth N Descend at most N levels. -maxdepth 0 applies
actions to command line arguments only
-mindepth N Don't act on first N levels
-depth Act on directory *after* traversing it
Actions:
( ACTIONS ) Group actions for -o / -a
! ACT Invert ACT's success/failure
ACT1 [-a] ACT2 If ACT1 fails, stop, else do ACT2
ACT1 -o ACT2 If ACT1 succeeds, stop, else do ACT2
Note: -a has higher priority than -o
-name PATTERN Match file name (w/o directory name) to PATTERN
-iname PATTERN Case insensitive -name
-path PATTERN Match path to PATTERN
-ipath PATTERN Case insensitive -path
-regex PATTERN Match path to regex PATTERN
-type X File type is X (one of: f,d,l,b,c,s,p)
-executable File is executable
-perm MASK At least one mask bit (+MASK), all bits (-MASK),
or exactly MASK bits are set in file's mode
-mtime DAYS mtime is greater than (+N), less than (-N),
or exactly N days in the past
-mmin MINS mtime is greater than (+N), less than (-N),
or exactly N minutes in the past
-newer FILE mtime is more recent than FILE's
-inum N File has inode number N
-user NAME/ID File is owned by given user
-group NAME/ID File is owned by given group
-size N[bck] File size is N (c:bytes,k:kbytes,b:512 bytes(def.))
+/-N: file size is bigger/smaller than N
-links N Number of links is greater than (+N), less than (-N),
or exactly N
-prune If current file is directory, don't descend into it
If none of the following actions is specified, -print is assumed
-print Print file name
-print0 Print file name, NUL terminated
-exec CMD ARG ; Run CMD with all instances of {} replaced by
file name. Fails if CMD exits with nonzero
-exec CMD ARG + Run CMD with {} replaced by list of file names
-delete Delete current file/directory. Turns on -depth option
-quit Exit
failed to resize tty, using default size
Had to run it seperately.
ash-4.3# sqlite3 bandwidth.db "PRAGMA integrity_check;"
ok
ash-4.3# sqlite3 heldamount.db "PRAGMA integrity_check;"
ok
ash-4.3# sqlite3 notifications.db "PRAGMA integrity_check;"
ok
ash-4.3# sqlite3 orders.db "PRAGMA integrity_check;"
ok
ash-4.3# sqlite3 piece_expiration.db "PRAGMA integrity_check;"
ok
ash-4.3# sqlite3 pieceinfo.db "PRAGMA integrity_check;"
ok
ash-4.3# sqlite3 piece_spaced_used.db "PRAGMA integrity_check;"
ok
ash-4.3# sqlite3 pricing.db "PRAGMA integrity_check;"
ok
ash-4.3# sqlite3 reputation.db "PRAGMA integrity_check;"
ok
ash-4.3# sqlite3 satellites.db "PRAGMA integrity_check;"
ok
ash-4.3# sqlite3 storage_usage.db "PRAGMA integrity_check;"
ok
ash-4.3# sqlite3 used_serial.db "PRAGMA integrity_check;"
ok
i’m running the docker version and i’ve never seen a hit of a memory leak, in fact i’ve been very impressed by it’s ability to keep memory usage of the storagenode at about 100mb.
and the node has been up continuously for two weeks now.
from what i understand also, tho haven’t really had problem’s with it myself, the memory usage can be related to write operations to disk… if we say your hdd cannot keep up with the iops… doesn’t have to be much… like say it can take 200iops and the storagenode needs 202
so in like 2 minutes it’s almost 1 second behind… and so if we get 1.5mb ingress a sec… then no big deal…
so lets just call it 1-1 mb to minutes… so 1440 minutes in a day… and lets say your machine has atleast 8gb… which gives you maybe 6 days before it would completely saturate your RAM
ofc most system will then try to swap, which easily could give you another big chunk…
i would suppose it could also damage the node if the system crashed …
anyways my point is that even tho your disk seems to be able to keep up, it might not be so… and it can cause what looks like a memory leak…
one easy patch would be to set the node to restart once in a while…
excuse the hole in the middle… no clue what this is about… netdata is kinda rough around the edges, maybe it crashed or something…
and really should get it correctly configured so i can use the graphs better…
anyways thats my memory usages… seems like the is basically no memory activity in the storagenode and the main part of the memory is used for rss
been checking it from time to time over the last few months… never seen it above 250mb… and that was only once i think when we had 5mb/s peak ingress
