As i writen, SC.exe is windows app that install and delete services.
type sc.exe delete storagenode1 in cmd, and cmd run as admin
Ah okay, and then should I setup a new node or should the old node run? Thank you for your answer
after that pleas run search on toolbox, to ensure you dont have several node services.
then can try install second node from scratch.
if it not make files again then i will find command to make it manualy from my source code.
and move identitie to c:\ path, may be it just cant get it from App directory, thats why cant make file
Yeah now it works thank you very much for your support
did you moved idenditie to c:\ location? just to know what can be problem source
i think problem is when path contain spases
Yes I moved the Identity to c:/ I think also it was the problem
