Please, show your port forwarding rule.
Perhaps you forwarded the 28968 port to a wrong node. The identity is signed, because I can see your node on the satellites, but the last contact is still NULL.
Also, seems you created a new identity.
Please, try to use the public IP from yougetsignal instead of DDNS
returned error, and shouldn’t be problem because even if dns service is working before node, node is offline
PS C:\WINDOWS\system32> sc config storagenode depend= dnscache
Set-Content : A positional parameter cannot be found that accepts argument ‘depend=’.
At line:1 char:1
Please, run this command in the elevated cmd, not Powershell. Or explicitly specify the extension for the sc command, like this sc.exe config storagenode depend= dnscache
You can try, since you already have the identity. Just stop the storagenode service.
If it work - then there is a potential bug.
But I think it will not work too
