Nextcloud on Storj?
Is there any news about cooperation?
Time goes by, I am looking for information and I do not see anything.
Hi @vovannovig! Check out this latest update as of a week ago :slight_smile:
https://apps.nextcloud.com/apps/storj
That’s great! Out of curiosity, how is this app making the use of the S3 gateway unnecessary?
Yes, I tested it and it works. With this app you do not need an s3-compatible gateway anymore.
Just follow instructions on GitHub.
After installation it will appear as a connection method in External storage.
I just tested the nextcloud storj app and encountered the following issue: while I am able to access my bucket, when downloading a file, it only downloads the first 64M of it. I also tried to upload a file (~120M) and only a 64M segment of it is effectively uploaded.
Anything I may have done wrong?
Thank you!
Unfortunately, I’ve had the same issue 1 year and a half ago :confused:
I don’t know if someone knows what’s happening and how to fix it. I thought it would be already fixed.
I did not experience any issue when combining Nextcloud with Storj S3 gateway (contrary to your experience 1 year and a half ago). Here, I’m only talking about the new standalone app for Nextcloud (which is definitely a very good improvement in terms of onboarding experience, if only it worked well :slightly_smiling_face:)
Any news on an upcoming update of this app? @Erikvv? Thanks!
I’ve just released a new version (v0.0.5) with the fix for this issue. It usually takes a day for the app store to display it.
Thanks @Erikvv! I’ll give it a try and provide my feedback ASAP.
Just bumped into this error:
The bucket name is correct as well as the access grant. Any idea what it could be about?
Thanks!
Created issue. I am befuddled as to why I don’t have this error.
What satellite are you on?
eu1 it is (and a couple more words for 20 chars)
Just to be sure, have you restarted fpm/apache after update?
(else it might have cached remnants of the old .so lib file)
Just restarted both services and the same error pops up :slightly_frowning_face:
We’ve made a fix of the suspected issue, that will be in the next deploy to the satellite.
@silaxe
Hi @Erikvv! Any update of the Storj app planned at some point?
I’m thinking about the issue I opened on Github: Interface with storj linksharing service? Ā· Issue #25 Ā· storj-thirdparty/nextcloud-app Ā· GitHub…
… But also the compatibility with Nextcloud 24?
Thanks in advance for the heads up :slight_smile:
I’m a bit behind on the maintenance of the app.
I don’t think I’ll get to your feature request because there’s about 6 maintenance and documentation tasks for existing features I’d like to do first. And then I have some other bindings-related things ongoing.
