Node continuously disqualified
I ran a node since StorJ ico. All of a sudden, out of the blue it was disqualified. Never given a reason, just disqualified. I deleted all data and configs and created a new node. Within a day, it was disqualified. I’ve done this process probably 5 times and all new nodes are disqualified within a day. How can I figure out what is causing this???
May be you have broken HDD, that write data with errors?
please make some test for it.
Also did you made also new identity with new signature token?
I can’t even think of how a new node could be DQ’d in a day? That’s not long enough to be vetted, or suspended from being offline, or even for it for it to fail enough audits. Are you sure you’re not recycling the Identity files?
Each time you grabbed a new Auth Token, and used it on a new Identity?
You know, repeating the same thing and expecting a different outcome.. is not wise.
Did you find the reason for disqualification?
How did you setup the node?
Did you get a new token for it? Did you generate and sign a new identity? New empty storage?
Verified node was online, and stayed online?
Monitored emails and looked at logs, at least immediately after node start, to confirm the handshake with satellite worked?
It’s very hard to get disqualified.
Einstein’s definition of insanity… love it.
2 cents,
Julio
