Hi.
My node is offline.I ran the log command and received this:
$ sudo docker logs --tail 30 storagenode
5443927s"}
2020-05-15T13:29:57.228Z ERROR piecestore:cache error getting current space used calculation: {“error”: “lstat config/storage/blobs/pmw6tvzmf2jv6giyybmmvl4o2ahqlaldsaeha4yx74n5aaaaaaaa/7w/yhbpbjjinob74p3wf7utjp2nzacq6clcjlhn5hhbakeiof2ceq.sj1: bad message; lstat config/storage/blobs/6r2fgwqz3manwt4aogq343bfkh2n5vvg4ohqqgggrrunaaaaaaaa/yk/2a2cmvnuudqazimxs3jnxaw2y7ton4q5ggdluzmgblggjekg2a.sj1: bad message”, “errorVerbose”: “group:\n— lstat config/storage/blobs/pmw6tvzmf2jv6giyybmmvl4o2ahqlaldsaeha4yx74n5aaaaaaaa/7w/yhbpbjjinob74p3wf7utjp2nzacq6clcjlhn5hhbakeiof2ceq.sj1: bad message\n— lstat config/storage/blobs/6r2fgwqz3manwt4aogq343bfkh2n5vvg4ohqqgggrrunaaaaaaaa/yk/2a2cmvnuudqazimxs3jnxaw2y7ton4q5ggdluzmgblggjekg2a.sj1: bad message”}
2020-05-15T13:29:57.229Z ERROR contact:service ping satellite failed {“Satellite ID”: “118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW”, “attempts”: 1, “error”: “ping satellite error: context canceled”, “errorVerbose”: “ping satellite error: context canceled\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:130\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:87\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2020-05-15T13:29:57.229Z ERROR contact:service ping satellite failed {“Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “attempts”: 1, “error”: “ping satellite error: context canceled”, “errorVerbose”: “ping satellite error: context canceled\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:130\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:87\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2020-05-15T13:29:57.230Z INFO contact:service context cancelled {“Satellite ID”: “118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW”}
2020-05-15T13:29:57.230Z INFO contact:service context cancelled {“Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”}
2020-05-15T13:29:57.231Z ERROR nodestats:cache Get pricing-model/join date failed {“error”: “context canceled”}
Error: lstat config/storage/blobs/pmw6tvzmf2jv6giyybmmvl4o2ahqlaldsaeha4yx74n5aaaaaaaa/7w/yhbpbjjinob74p3wf7utjp2nzacq6clcjlhn5hhbakeiof2ceq.sj1: bad message; lstat config/storage/blobs/6r2fgwqz3manwt4aogq343bfkh2n5vvg4ohqqgggrrunaaaaaaaa/yk/2a2cmvnuudqazimxs3jnxaw2y7ton4q5ggdluzmgblggjekg2a.sj1: bad message
2020-05-15T13:30:59.670Z INFO Configuration loaded {“Location”: “/app/config/config.yaml”}
2020-05-15T13:30:59.671Z INFO tracing disabled
2020-05-15T13:30:59.673Z INFO Operator email {“Address”: “ilan.klein1@gmail.com”}
2020-05-15T13:30:59.673Z INFO Operator wallet {“Address”: “0x99969Df2dA9BF780Cfd62D7cC22f77E5BdB332df”}
2020-05-15T13:31:00.009Z INFO db.migration Database Version {“version”: 36}
2020-05-15T13:31:00.735Z INFO preflight:localtime start checking local system clock with trusted satellites’ system clock.
2020-05-15T13:31:01.380Z INFO preflight:localtime local system clock is in sync with trusted satellites’ system clock.
2020-05-15T13:31:01.380Z INFO bandwidth Performing bandwidth usage rollups
2020-05-15T13:31:01.382Z INFO Node 1FAXWhjtehvS8Dyj7avb5tvqrCderxtKE3XZZJ2vvYnTnfoQYt started
2020-05-15T13:31:01.382Z INFO Public server started on [::]:28967
2020-05-15T13:31:01.382Z INFO Private server started on 127.0.0.1:7778
2020-05-15T13:31:01.384Z INFO trust Scheduling next refresh {“after”: “6h37m8.303837355s”}
2020-05-15T13:31:02.349Z ERROR piecestore:cache error getting current space used calculation: {“error”: “lstat config/storage/blobs/pmw6tvzmf2jv6giyybmmvl4o2ahqlaldsaeha4yx74n5aaaaaaaa/7w/yhbpbjjinob74p3wf7utjp2nzacq6clcjlhn5hhbakeiof2ceq.sj1: bad message; lstat config/storage/blobs/6r2fgwqz3manwt4aogq343bfkh2n5vvg4ohqqgggrrunaaaaaaaa/yk/2a2cmvnuudqazimxs3jnxaw2y7ton4q5ggdluzmgblggjekg2a.sj1: bad message”, “errorVerbose”: “group:\n— lstat config/storage/blobs/pmw6tvzmf2jv6giyybmmvl4o2ahqlaldsaeha4yx74n5aaaaaaaa/7w/yhbpbjjinob74p3wf7utjp2nzacq6clcjlhn5hhbakeiof2ceq.sj1: bad message\n— lstat config/storage/blobs/6r2fgwqz3manwt4aogq343bfkh2n5vvg4ohqqgggrrunaaaaaaaa/yk/2a2cmvnuudqazimxs3jnxaw2y7ton4q5ggdluzmgblggjekg2a.sj1: bad message”}
2020-05-15T13:31:02.350Z ERROR nodestats:cache Get pricing-model/join date failed {“error”: “context canceled”}
2020-05-15T13:31:02.350Z ERROR contact:service ping satellite failed {“Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “attempts”: 1, “error”: “ping satellite error: context canceled”, “errorVerbose”: “ping satellite error: context canceled\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:130\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:87\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2020-05-15T13:31:02.350Z INFO contact:service context cancelled {“Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”}
2020-05-15T13:31:02.350Z ERROR contact:service ping satellite failed {“Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “attempts”: 1, “error”: “ping satellite error: context canceled”, “errorVerbose”: “ping satellite error: context canceled\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:130\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:87\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2020-05-15T13:31:02.351Z INFO contact:service context cancelled {“Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”}
Any idea what is going on?
Thanks
Ilan
