Hi,
I had some issues with my node and had to move over from the docker version to the Windows GUI for V3 beta testing. It appears that my post disappeared for some reason however.
Now that I am on the GUI and have some left over files in my blobs folder, I didn’t want to lose my files and have to start over. However, once I launch the node, the free space on the drive is not correctly reflected. It says that there is 1.5TB free when in fact there is 0.5TB free.
Here is the error message I am getting in my log file:
2019-12-21T13:38:30.067-0700 | ERROR | piecestore:cacheUpdate | error getting current space used calculation: | {“error”: “context canceled”} |
2019-12-21T13:38:30.068-0700 | ERROR | piecestore:cacheUpdate | error persisting cache totals to the database: | {“error”: “piece space used error: context canceled”, “errorVerbose”: “piece space used error: context canceled\n\tstorj.io/storj/storagenode/storagenodedb.(*pieceSpaceUsedDB).UpdateTotal:115\n\tstorj.io/storj/storagenode/pieces.(*CacheService).PersistCacheTotals:82\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:68\n\tstorj.io/storj/private/sync2.(*Cycle).Run:87\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:63\n\tstorj.io/storj/storagenode.(*Peer).Run.func6:453\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”} |
