I see. Could you give me a NodeID? You can send it via PM.
Found the solution! My fault, of course… Updated a secondary DNS zone and forgot to update the actual master one, therefore the DNS was still pointing to my old IP.
Thanks for the support debugging the issue!
i too am having this same problem, though i am using v3 in a docker on unraid, it’s set to “host” so that it’s the same ip as the server, i checked all the port assignments so there are no conflicts there, i am including all the screens and verifications, and it’s still showing offline.
[Edit] Removed images]
i would apreciate any help given. thank you.
[Edit:] Found my problem, had to have the images in front of me to find it. it was the port assignment ni the docker container changed when it was updating.
Your showing a different port on your dashboard that your using, vs showing which port is open.
thank you, you got to it before i could finish my edit.
lol
Thats perfect then. Was an easy fix.
