How about you stop all the proxies first? Lets run the test again with a single IP and see how that works!
You can no longer rely on that metric for ingress, since there was a change to how bandwidth is reported by the API on v1.104
Any chance we could have a config option to disable all file walkers from automatically running and command line options to run them ourselves âmanuallyâ? That way more advanced SNOs could write their own scripts in order to optimize performance based on their particular hardware. We could implement a staggered approach to running them so they donât all run at once, or delay them to run during times of less network demand, etc.
Additionally, is / would it be possible to reload the config file without completely restarting the node?
You can disable only used-space-filewalker, which is triggered on startup. All others doesnât have a disable option.
You may submit a feature request on GitHub or here: Storage Node feature requests - voting - Storj Community Forum (official), or submit a pull request with the needed change - we are happy to accept any Community contribution!
Canât find the exact model numbers, but EFAX sounds like an SMR drive.
Does the drive report TRIM support?
Yes > 100% SMR
No > CMR
So Efax disk is CMR and Efbx is SMR, and anyway they are bastards with this smr/cmr game
Not really.
Decoding that part number:
WD80EFAX
>8,0
>TB, desktop 3.5"
>Red
>5400rpm, 256MB cache
>6GBps SATA
Canât say if itâs SMR or CMR from the model number unless it matches with current WD documentation (they pulled some off the site when the SMR/CMR debacle happened). Only the drive itself can tells us that, so see comment above about trim support.
And how do I see if they support trim? Itâs not just for SSDsâŚ
If youâre on linux you can try
smarctl -i /dev/sd*
(obviously replacing /dev/sd* with whatever the drive youâre trying to check is living on
If TRIM is enabled it should come up with a line saying something like
TRIM Command: Available, deterministic, zeroed
apt install smartmontools
there is a typo, the command is: smartctl
There is no more Optware in AppCenter of Qnap. There is EntwareâŚ
but seems not work
