After last nights firmware upgrade, the node stopped working.
Since I still had the not working app installed during this proces, I’ve noted down below what I’ve done ever since the first time I tried to get it up and running
This is how I ran the node so far:
- StorJ app installed (but failed to get this running
- Installed the node via SSH worked (app was still there)
- I’ve since rebooted the NAS three times (2 times for a disk upgrade, node still worked, app still installed)
- Last reboot was for maintenance (NAS asked to do so before firmware update)
- After firmware update node didn’t come back online (last night, so keep in mind it didn’t work for a full evening if that matters somehow)
- This morning I’ve removed the app, stopped the running docker image, and went for a fresh pull from latest
- Nothing has changed in the network, port is also still open according the the open port check tool
Run command
-p 28967:28967
-p 14002:14002
-e WALLET=“xxxxx”
-e EMAIL="xxxxx@gmail.com"
-e ADDRESS=“xx.xx.xx.xx:28967”
-e BANDWIDTH=“1TB”
-e STORAGE=“500GB”
–mount type=bind,source="/share/Public/identity/storagenode",destination=/app/identity
–mount type=bind,source="/share/Public/storj",destination=/app/config
Error
2021-04-14T08:25:15.117Z INFO Configuration loaded {“Location”: “/app/config/config.yaml”}
2021-04-14T08:25:15.153Z INFO Operator email {“Address”: “xxxx@gmail.com”}
2021-04-14T08:25:15.154Z INFO Operator wallet {“Address”: “xxxx”}
2021-04-14T08:25:46.336Z INFO Telemetry enabled {“instance ID”: “xxxx”}
2021-04-14T08:25:47.400Z INFO db.migration Database Version {“version”: 51}
2021-04-14T08:26:19.158Z WARN trust Failed to fetch URLs from source; used cache {“source”: “https://tardigrade.io/trusted-satellites”, “error”: “HTTP source: Get “https://tardigrade.io/trusted-satellites”: dial tcp 75.2.60.5:443: i/o timeout”, “errorVerb
ose”: “HTTP source: Get “https://tardigrade.io/trusted-satellites”: dial tcp 75.2.60.5:443: i/o timeout\n\tstorj.io/storj/storagenode/trust.(*HTTPSource).FetchEntries:63\n\tstorj.io/storj/storagenode/trust.(*List).fetchEntries:90\n\tstorj.io/storj/storagenode/trust.(*Li
st).FetchURLs:49\n\tstorj.io/storj/storagenode/trust.(*Pool).fetchURLs:240\n\tstorj.io/storj/storagenode/trust.(*Pool).Refresh:177\n\tstorj.io/storj/storagenode.(*Peer).Run:831\n\tmain.cmdRun:218\n\tstorj.io/private/process.cleanup.func1.4:363\n\tstorj.io/private/process.
cleanup.func1:381\n\tgithub.com/spf13/cobra.(*Command).execute:842\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:950\n\tgithub.com/spf13/cobra.(*Command).Execute:887\n\tstorj.io/private/process.ExecWithCustomConfig:88\n\tstorj.io/private/process.ExecCustomDebug:70\n\tmain
.main:385\n\truntime.main:204”}
2021-04-14T08:26:19.194Z INFO preflight:localtime start checking local system clock with trusted satellites’ system clock.
2021-04-14T08:26:39.195Z ERROR preflight:localtime unable to get satellite system time {“Satellite ID”: “12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo”, “error”: “rpc: dial tcp 35.227.56.124:7777: i/o timeout”, “errorVerbose”: “rpc: dial tcp 35.227.5
6.124:7777: i/o timeout\n\tstorj.io/common/rpc.TCPConnector.DialContextUnencrypted:106\n\tstorj.io/common/rpc.TCPConnector.DialContext:70\n\tstorj.io/common/rpc.Dialer.dialEncryptedConn:180\n\tstorj.io/common/rpc.Dialer.DialNodeURL.func1:101\n\tstorj.io/common/rpc/rpcpool
.(*Pool).Get:87\n\tstorj.io/common/rpc.Dialer.dialPool:146\n\tstorj.io/common/rpc.Dialer.DialNodeURL:100\n\tstorj.io/storj/storagenode/preflight.(*LocalTime).getSatelliteTime:110\n\tstorj.io/storj/storagenode/preflight.(*LocalTime).Check.func1:67\n\tgolang.org/x/sync/errg
roup.(*Group).Go.func1:57”}
2021-04-14T08:26:39.195Z ERROR preflight:localtime unable to get satellite system time {“Satellite ID”: “12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB”, “error”: “rpc: dial tcp 35.228.10.185:7777: i/o timeout”, “errorVerbose”: “rpc: dial tcp 35.228.
10.185:7777: i/o timeout\n\tstorj.io/common/rpc.TCPConnector.DialContextUnencrypted:106\n\tstorj.io/common/rpc.TCPConnector.DialContext:70\n\tstorj.io/common/rpc.Dialer.dialEncryptedConn:180\n\tstorj.io/common/rpc.Dialer.DialNodeURL.func1:101\n\tstorj.io/common/rpc/rpcpoo
l.(*Pool).Get:87\n\tstorj.io/common/rpc.Dialer.dialPool:146\n\tstorj.io/common/rpc.Dialer.DialNodeURL:100\n\tstorj.io/storj/storagenode/preflight.(*LocalTime).getSatelliteTime:110\n\tstorj.io/storj/storagenode/preflight.(*LocalTime).Check.func1:67\n\tgolang.org/x/sync/err
group.(*Group).Go.func1:57”}
2021-04-14T08:26:39.195Z ERROR preflight:localtime unable to get satellite system time {“Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “error”: “rpc: dial tcp 35.236.51.151:7777: i/o timeout”, “errorVerbose”: “rpc: dial tcp 35.236.5
1.151:7777: i/o timeout\n\tstorj.io/common/rpc.TCPConnector.DialContextUnencrypted:106\n\tstorj.io/common/rpc.TCPConnector.DialContext:70\n\tstorj.io/common/rpc.Dialer.dialEncryptedConn:180\n\tstorj.io/common/rpc.Dialer.DialNodeURL.func1:101\n\tstorj.io/common/rpc/rpcpool
roup.(Group).Go.func1:57"}
2021-04-14T08:26:39.195Z ERROR preflight:localtime unable to get satellite system time {“Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “error”: “rpc: dial tcp 34.107.91.2:7777: i/o timeout”, “errorVerbose”: "rpc: dial tcp 34.107.91
.2:7777: i/o timeout\n\tstorj.io/common/rpc.TCPConnector.DialContextUnencrypted:106\n\tstorj.io/common/rpc.TCPConnector.DialContext:70\n\tstorj.io/common/rpc.Dialer.dialEncryptedConn:180\n\tstorj.io/common/rpc.Dialer.DialNodeURL.func1:101\n\tstorj.io/common/rpc/rpcpool.(
Pool).Get:87\n\tstorj.io/common/rpc.Dialer.dialPool:146\n\tstorj.io/common/rpc.Dialer.DialNodeURL:100\n\tstorj.io/storj/storagenode/preflight.(*LocalTime).getSatelliteTime:110\n\tstorj.io/storj/storagenode/preflight.(*LocalTime).Check.func1:67\n\tgolang.org/x/sync/errgrou
2021-04-14T08:26:39.195Z ERROR preflight:localtime unable to get satellite system time {“Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “error”: “rpc: dial tcp 35.241.93.116:7777: i/o timeout”, “errorVerbose”: “rpc: dial tcp 35.241.
93.116:7777: i/o timeout\n\tstorj.io/common/rpc.TCPConnector.DialContextUnencrypted:106\n\tstorj.io/common/rpc.TCPConnector.DialContext:70\n\tstorj.io/common/rpc.Dialer.dialEncryptedConn:180\n\tstorj.io/common/rpc.Dialer.DialNodeURL.func1:101\n\tstorj.io/common/rpc/rpcpoo
2021-04-14T08:26:39.196Z ERROR preflight:localtime unable to get satellite system time {“Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “error”: “rpc: dial tcp 34.70.108.161:7777: i/o timeout”, “errorVerbose”: “rpc: dial tcp 34.70.1
08.161:7777: i/o timeout\n\tstorj.io/common/rpc.TCPConnector.DialContextUnencrypted:106\n\tstorj.io/common/rpc.TCPConnector.DialContext:70\n\tstorj.io/common/rpc.Dialer.dialEncryptedConn:180\n\tstorj.io/common/rpc.Dialer.DialNodeURL.func1:101\n\tstorj.io/common/rpc/rpcpoo
2021-04-14T08:26:39.196Z ERROR Failed preflight check. {“error”: “system clock is out of sync: system clock is out of sync with all trusted satellites”, “errorVerbose”: “system clock is out of sync: system clock is out of sync with all trusted satellites\n\tstorj
.io/storj/storagenode/preflight.(*LocalTime).Check:96\n\tstorj.io/storj/storagenode.(*Peer).Run:835\n\tmain.cmdRun:218\n\tstorj.io/private/process.cleanup.func1.4:363\n\tstorj.io/private/process.cleanup.func1:381\n\tgithub.com/spf13/cobra.(*Command).execute:842\n\tgithub.
com/spf13/cobra.(*Command).ExecuteC:950\n\tgithub.com/spf13/cobra.(*Command).Execute:887\n\tstorj.io/private/process.ExecWithCustomConfig:88\n\tstorj.io/private/process.ExecCustomDebug:70\n\tmain.main:385\n\truntime.main:204”}
Error: system clock is out of sync: system clock is out of sync with all trusted satellites
2021-04-14T08:26:44.191Z INFO Configuration loaded {“Location”: “/app/config/config.yaml”}
2021-04-14T08:26:44.198Z INFO Operator email {“Address”: “xxxx@gmail.com”}
2021-04-14T08:26:44.199Z INFO Operator wallet {“Address”: “xxxx”}
