got it. Ill keep an eye on it. Is the below command what i want to use to check logs periodically?
docker logs storagenode 2>&1 | grep -E "GET_AUDIT|GET_REPAIR" | grep failed
Yep, that should do it. Be sure to post if you see any remaining errors.
looks like a lot less errors. but i am seeing some new ones come through that look like the below. Am i hosed? lol
2022-01-11T23:24:12.730Z ERROR piecestore download failed {"Piece ID": "4M7ICXOI7RB3DWT2MLQWXIILYCO7NPHCDWCLSIIPNEUQF6ZP3FBQ", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "GET_REPAIR", "error": "file does not exist", "errorVerbose": "file does not exist\n\tstorj.io/common/rpc/rpcstatus.Wrap:73\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download:545\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:228\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:58\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:104\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:60\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:97\n\tstorj.io/drpc/drpcctx.(*Tracker).track:52"}
2022-01-11T23:49:18.237Z ERROR piecestore download failed {"Piece ID": "4N3WLCAEAVGMG6O5RTANVTBOJO6WCE5PKAVQIGNHPVI5GQTT7KLA", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "GET_REPAIR", "error": "file does not exist", "errorVerbose": "file does not exist\n\tstorj.io/common/rpc/rpcstatus.Wrap:73\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download:545\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:228\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:58\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:104\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:60\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:97\n\tstorj.io/drpc/drpcctx.(*Tracker).track:52"}
Unfortunately this does suggest permanent data loss. Your node may survive, but your scores will always fluctuate. It really depends on how much data you lost.
Arenât you supposed to run the repair on the partition (i.e. sda1) instead of the drive itself (i.e. sda). Iâm not sure if the repair was performed correctly.
At least this was the problem for me a couple of days ago with a broken filesystem after power loss. I had to use xfs_repair in my case. YMMV ofcourse
i would think it depends on what filesystems is supported by the tool being used to repair the filesystem.
sda would be the entire drive, but whatever tool one is using might allow one to use the entire disk name, to fix it⌠like say if you only have 1 partition containing an xfs filesystem, it might not matter how you write it.
the partition isnât really the filesystem contained on a partition, another option one can use for verifying hddâs or ssdâs is smartctl, which can be good for identifying hardware issues with the disk, which can cause the other issues⌠but like bright said, often hddâs just make errors and that damages the filesystem.
the partition itself is rarely damaged because its rarely changed, only when you change filesystems on a partition does it really get changed. afaik
but the nitty gritty details of how hddâs really work is a rather complex topic
donât think it matters much what one uses to repair with, tho some high end tools are significantly better than others, atleast for data recoveryâŚ
however data recovery is a science in itself and the tools fairly expensive.
if data loss is critical and recovery needed, one should disconnect the drive immediately and take it to a professional, for the best odds of recovering the data.
hddâs seems to much more likely to have errors than ssdâs, but thats not really a big surprise since one is mechanical and the other solid state.
you might want to check the smart of the hdd and get a sense of if it has any hardware issues.
this looks to have all checked out. so i will let the node run for a bit and see what happens.
If my scores on audit fluctuate, how bad is that?
DQ is at 60% audit score, anything higher than that is generally fine⌠ofc you want to see it as high as possible, but not much one can do to change it⌠itâs just a gauge of how well the node is doing.
by generally fine i mean, iâm unaware of any real detrimental effects.
got it i appreciate the info. I have audits around 90-94% now. which seems ok, but it has the yellow exclamation point next to a couple of satellites. i will monitor and see if it goes below that to 60%. maybe i just had a power surge that messed up some stuff.
