Can you show screenshot of the dashboard?
like this ?
I just find out that if I browse the Dashboard on local network it will show the last contact bad ( negative ) but if I browse it from localhost it will show positive
What is TimeZone on your host with storagenode and on your other device?
Yes the time is different on host and the server(container) , Im looking the way to change the time on the docker container to match the host
The docker uses the host’s time. So, your host has a different TZ from the system where you open your dashboard
