Stob
21
Any command which begins sqlite3 must be run from C:\sqlite\ like above…
PS C:\sqlite> .\sqlite3.exe F:\Storj2\bandwidth.db ".read F:\dump_all_notrans.sql"
edit - What is the size of the .sql files in your screenshot? If any are 0 bytes then the commands did not work.
Alexey
22
The command
Get-Content f:\Storj2dump_all.sql | Select-String -NotMatch TRANSACTION | Select-String -NotMatch ROLLBACK | Select-String -NotMatch COMMIT | Set-Content -Encoding utf8 f:\dump_all_notrans.sql
should be run from the PowerShell, not sqlite3 prompt.
Aka985
23
Well, I did like this:
Standing, cursor is blinking
Database files are not zero:
DB file size slowly increasing:
Is it normal? Just wait and start Storj service than/if complete? P.15 is not needed for my case if I understood right.
Regards,
Alexander
Stob
24
This is correct. When I ran this on my node it took quite some time.
Aka985
25
It works!
Parameters are not OK, but hope it will recover
Thank you guys for such professional and tolerant support!
Regards,
Alexander
Stob
26
Yes, keep node online and in 30 days the online scores should be back to 100%
