Nodes fails on morning
Hey, i have 2 nodes running in unraid, db is on nvme, every morning i get notifications by email that my nodes are offline. They are running but the logs are basicly dead, no traffic, after restart everything works.
Any idea?
Thanks in advance!
Logs:
ERROR Error retrieving version info. {“process”: “storagenode-updater”, “error”: “version checker client: Get "https://version.storj.io": context deadline exceeded (Client.Timeout exceeded while awaiting headers)”, “errorVerbose”: “version checker client: Get "https://version.storj.io": context deadline exceeded (Client.Timeout exceeded while awaiting headers)\n\tstorj.io/storj/private/version/checker.(*Client).All:68\n\tmain.loopFunc:20\n\tstorj.io/common/sync2.(*Cycle).Run:163\n\tmain.cmdRun:141\n\tstorj.io/common/process.InitBeforeExecute.func1.2:389\n\tstorj.io/common/process.InitBeforeExecute.func1:407\n\tgithub.com/spf13/cobra.(*Command).execute:1015\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1148\n\tgithub.com/spf13/cobra.(*Command).Execute:1071\n\tstorj.io/common/process.ExecWithCustomOptions:115\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:80\n\tmain.main:22\n\truntime.main:290”}
ERROR piecestore upload internal error {“process”: “storagenode”, “error”: “manager closed: write tcp xyz:28967->xyz:54942: write: connection timed out”, “errorVerbose”: "manager closed: write tcp 1xyz:28967->xyz:54942: write: connection timed out\n\tgithub.com/jtolio/noiseconn.(*Conn).Read:154\n\tstorj.io/drpc/drpcwire.(*Reader).read:68\n
2026-11-02T06:27:59+01:00 ERROR version failed to get process version info {“process”: “storagenode”, “error”: “version checker client: Get "https://version.storj.io": piecestore monitor: timed out after 1m0s while verifying writability of storage directory”, “errorVerbose”: “version checker client: Get "https://version.storj.io": piecestore monitor: timed out after 1m0s while verifying writability of storage directory\n\tstorj.io/storj/private/version/checker.(*Client).All:68\n\tstorj.io/storj/private/version/checker.(*Client).Process:89\n\tstorj.io/storj/private/version/checker.(*Service).checkVersion:104\n\tstorj.io/storj/private/version/checker.(*Service).CheckVersion:78\n\tstorj.io/storj/storagenode/version.(*Chore).checkVersion:115\n\tstorj.io/storj/storagenode/version.(*Chore).RunOnce:71\n\tstorj.io/common/sync2.(*Cycle).Run:163\n\tstorj.io/storj/storagenode/version.(*Chore).Run:64\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:57\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:93”}
ERROR orders failed to settle orders for satellite {“process”: “storagenode”, “satellite_id”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “satellite_id”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “error”: “order: failed to start settlement: rpc: tcp connector failed: rpc: dial tcp: lookup eu1.storj.io: operation was canceled”, “errorVerbose”: “order: failed to start settlement: rpc: tcp connector failed: rpc: dial tcp: lookup eu1.storj.io: operation was canceled\n\tstorj.io/storj/storagenode/orders.(*Service).settleWindow:264\n\tstorj.io/storj/storagenode/orders.(*Service).SendOrders.func2:219\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:93”}
2026-11-02T06:27:59+01:00 ERROR orders failed to settle orders for satellite {“process”: “storagenode”, “satellite_id”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “satellite_id”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “error”: “order: failed to start settlement: rpc: tcp connector failed: rpc: dial tcp: lookup saltlake.tardigrade.io: operation was canceled”, “errorVerbose”: “order: failed to start settlement: rpc: tcp connector failed: rpc: dial tcp: lookup saltlake.tardigrade.io: operation was canceled\n\tstorj.io/storj/storagenode/orders.(*Service).settleWindow:264\n\tstorj.io/storj/storagenode/orders.(*Service).SendOrders.func2:219\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:93”}
2026-11-02T06:27:59+01:00 INFO Current binary version {“process”: “storagenode-updater”, “service”: “storagenode-updater”, “version”: “v1.164.2”}
2026-11-02T06:27:59+01:00 INFO Version is up to date {“process”: “storagenode-updater”, “service”: “storagenode-updater”}
2026-11-02T06:27:59+01:00 INFO Downloading versions. {“process”: “storagenode-updater”, “server_address”: “https://version.storj.io”}
2026-11-02T06:27:59+01:00 INFO Current binary version {“process”: “storagenode-updater”, “service”: “storagenode”, “version”: “v1.164.2”}
2026-11-02T06:27:59+01:00 INFO Version is up to date {“process”: “storagenode-updater”, “service”: “storagenode”}
2026-11-02T06:28:14+01:00 WARN servers service takes long to shutdown {“process”: “storagenode”, “name”: “server”}
2026-11-02T06:28:14+01:00 INFO servers slow shutdown {“process”: “storagenode”, “stack”: "goroutine 92\n\tstorj.io/storj/private/lifecycle.(*Group)
Your storage drives are too slow.
  1. Change your DDNS.
  2. Bump up your flag in config.yaml, as a workaround:
    storage2.monitor.verify-dir-writable-timeout: 2m0s or 3m30s.
    maybe even your readable timeout storage2.monitor.verify-dir-readable-timeout: [match above]
  3. fix your drive fragmentation, likely it’s a mess after/during transition to hashstore.
2 cents,
Julio
I wouldn’t recommend to increase the readability timeout, it will hide the problem, not solve it, and the node might start to fail audits (there is a very short timeout for these requests). It’s better to improve the disk subsystem to be more responsive.
If you would increase a writability timeout higher than 5 minutes you would also need to increase a writability check interval to the same value.
