Hi,
I received an email my nodes is suspended but all Audit Satellite is perfect (100%)
Does anyone have the same problem? but 20 other nodes work fine.
Hi,
I have the same issue. Can you please explain how to check log entries? I’m running on a Linux server with the standard Docker setup.
Cliff.
Sorry,
I even found my linux does not start anymore there are critical errors on the HDD …
the suspension is justified…
Fix it asap before your node is disqualified for failing to answer audits.
