Nodes restart due to input/outpur error
Hello guys,
on one of my node I’m having the problem right now, that it doesn’t run and keeps crashing and restarting. It must have been hardware errors, I already unmouted it, ran e2fsck, it fixed alot and now it seems to keep having the problem.
2026-03-16T19:27:53Z	INFO	hashstore	loaded hint file	{"process": "storagenode", "satellite": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "store": "s0", "path": "config/storage/hashstore/121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6/s0/meta/hint-000000000000028a", "writable": [847, 846, 848, 845, 832, 829, 826, 77], "largest": 848, "skip": false}
2026-03-16 19:27:54,535 INFO success: processes-exit-eventlistener entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2026-03-16 19:27:54,536 INFO success: storagenode entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2026-03-16 19:27:54,536 INFO success: storagenode-updater entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2026-03-16T19:27:56Z	INFO	hashstore	unclean shutdown detected: reconciling logs	{"process": "storagenode", "satellite": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "store": "s0"}
2026-03-16T19:28:00Z	INFO	hashstore	loaded hint file	{"process": "storagenode", "satellite": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "store": "s1", "path": "config/storage/hashstore/121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6/s1/meta/hint-00000000000001ea", "writable": [627, 628, 625], "largest": 628, "skip": false}
2026-03-16T19:28:02Z	INFO	hashstore	unclean shutdown detected: reconciling logs	{"process": "storagenode", "satellite": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "store": "s1"}
2026-03-16T19:28:04Z	INFO	hashstore	hashstore opened successfully	{"process": "storagenode", "satellite": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "open_time": "10.71617208s", "logs_skipped": 126, "logs_matched": 11, "logs_mismatched": 0}
2026-03-16T19:28:04Z	INFO	hashstore	loaded hint file	{"process": "storagenode", "satellite": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "store": "s0", "path": "config/storage/hashstore/12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S/s0/meta/hint-0000000000000141", "writable": [], "largest": 0, "skip": false}
2026-03-16T19:28:13Z	ERROR	failure during run	{"process": "storagenode", "error": "Failed to create storage node peer: hashstore: read config/storage/hashstore/12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S/s0/meta/hashtbl-0000000000000145: input/output error\n\tstorj.io/storj/storagenode/hashstore.(*roBigPageCache).ReadRecord:649\n\tstorj.io/storj/storagenode/hashstore.(*HashTbl).Range:320\n\tstorj.io/storj/storagenode/hashstore.(*HashTbl).loadEntries:264\n\tstorj.io/storj/storagenode/hashstore.OpenHashTbl:176\n\tstorj.io/storj/storagenode/hashstore.OpenTable:120\n\tstorj.io/storj/storagenode/hashstore.NewStore:261\n\tstorj.io/storj/storagenode/hashstore.New:110\n\tstorj.io/storj/storagenode/piecestore.(*HashStoreBackend).getDB:272\n\tstorj.io/storj/storagenode/piecestore.NewHashStoreBackend:122\n\tstorj.io/storj/storagenode.New:607\n\tmain.cmdRun:84\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.InitBeforeExecute.func1.2:389\n\tstorj.io/common/process.InitBeforeExecute.func1:407\n\tgithub.com/spf13/cobra.(*Command).execute:985\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1117\n\tgithub.com/spf13/cobra.(*Command).Execute:1041\n\tstorj.io/common/process.ExecWithCustomOptions:115\n\tmain.main:34\n\truntime.main:285", "errorVerbose": "Failed to create storage node peer: hashstore: read config/storage/hashstore/12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S/s0/meta/hashtbl-0000000000000145: input/output error\n\tstorj.io/storj/storagenode/hashstore.(*roBigPageCache).ReadRecord:649\n\tstorj.io/storj/storagenode/hashstore.(*HashTbl).Range:320\n\tstorj.io/storj/storagenode/hashstore.(*HashTbl).loadEntries:264\n\tstorj.io/storj/storagenode/hashstore.OpenHashTbl:176\n\tstorj.io/storj/storagenode/hashstore.OpenTable:120\n\tstorj.io/storj/storagenode/hashstore.NewStore:261\n\tstorj.io/storj/storagenode/hashstore.New:110\n\tstorj.io/storj/storagenode/piecestore.(*HashStoreBackend).getDB:272\n\tstorj.io/storj/storagenode/piecestore.NewHashStoreBackend:122\n\tstorj.io/storj/storagenode.New:607\n\tmain.cmdRun:84\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.InitBeforeExecute.func1.2:389\n\tstorj.io/common/process.InitBeforeExecute.func1:407\n\tgithub.com/spf13/cobra.(*Command).execute:985\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1117\n\tgithub.com/spf13/cobra.(*Command).Execute:1041\n\tstorj.io/common/process.ExecWithCustomOptions:115\n\tmain.main:34\n\truntime.main:285\n\tmain.cmdRun:86\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.InitBeforeExecute.func1.2:389\n\tstorj.io/common/process.InitBeforeExecute.func1:407\n\tgithub.com/spf13/cobra.(*Command).execute:985\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1117\n\tgithub.com/spf13/cobra.(*Command).Execute:1041\n\tstorj.io/common/process.ExecWithCustomOptions:115\n\tmain.main:34\n\truntime.main:285"}
Error: Failed to create storage node peer: hashstore: read config/storage/hashstore/12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S/s0/meta/hashtbl-0000000000000145: input/output error
	main.cmdRun:84
	main.main:34
	runtime.main:285
2026-03-16 19:28:13,594 INFO exited: storagenode (exit status 1; not expected)
2026-03-16 19:28:14,598 INFO spawned: 'storagenode' with pid 129
2026-03-16 19:28:14,598 WARN received SIGQUIT indicating exit request
2026-03-16 19:28:14,599 INFO waiting for storagenode, processes-exit-eventlistener, storagenode-updater to die
2026-03-16T19:28:14Z	INFO	Got a signal from the OS: "terminated"	{"process": "storagenode-updater"}
2026-03-16 19:28:14,603 INFO stopped: storagenode-updater (exit status 0)
2026-03-16 19:28:14,604 INFO stopped: storagenode (terminated by SIGTERM)
2026-03-16 19:28:14,605 INFO stopped: processes-exit-eventlistener (terminated by SIGTERM)
2026-03-16 19:28:14,976 INFO Set uid to user 0 succeeded
2026-03-16 19:28:14,978 INFO RPC interface 'supervisor' initialized
2026-03-16 19:28:14,978 INFO supervisord started with pid 1
2026-03-16 19:28:15,980 INFO spawned: 'processes-exit-eventlistener' with pid 11
2026-03-16 19:28:15,982 INFO spawned: 'storagenode' with pid 12
2026-03-16 19:28:15,983 INFO spawned: 'storagenode-updater' with pid 13
2026-03-16T19:28:16Z	INFO	Configuration loaded	{"process": "storagenode-updater", "location": "/app/config/config.yaml"}
2026-03-16T19:28:16Z	INFO	Invalid configuration file key	{"process": "storagenode-updater", "key": "operator.wallet-features"}
2026-03-16T19:28:16Z	INFO	Invalid configuration file key	{"process": "storagenode-updater", "key": "pieces.enable-lazy-filewalker"}
2026-03-16T19:28:16Z	INFO	Invalid configuration file key	{"process": "storagenode-updater", "key": "console.address"}
2026-03-16T19:28:16Z	INFO	Invalid configuration file key	{"process": "storagenode-updater", "key": "hashstore.compaction.alive-fraction"}
2026-03-16T19:28:16Z	INFO	Invalid configuration file key	{"process": "storagenode-updater", "key": "operator.email"}
2026-03-16T19:28:16Z	INFO	Invalid configuration file key	{"process": "storagenode-updater", "key": "healthcheck.enabled"}
2026-03-16T19:28:16Z	INFO	Invalid configuration file key	{"process": "storagenode-updater", "key": "contact.external-address"}
2026-03-16T19:28:16Z	INFO	Invalid configuration file key	{"process": "storagenode-updater", "key": "hashstore.compaction.delete-trash-immediately"}
2026-03-16T19:28:16Z	INFO	Invalid configuration file key	{"process": "storagenode-updater", "key": "hashstore.compaction.expires-days"}
2026-03-16T19:28:16Z	INFO	Invalid configuration file key	{"process": "storagenode-updater", "key": "operator.wallet"}
2026-03-16T19:28:16Z	INFO	Invalid configuration file key	{"process": "storagenode-updater", "key": "storage.allocated-disk-space"}
2026-03-16T19:28:16Z	INFO	Invalid configuration file key	{"process": "storagenode-updater", "key": "storage2.trust.exclusions"}
2026-03-16T19:28:16Z	INFO	Invalid configuration file key	{"process": "storagenode-updater", "key": "server.address"}
2026-03-16T19:28:16Z	INFO	Invalid configuration file key	{"process": "storagenode-updater", "key": "storage2.piece-scan-on-startup"}
2026-03-16T19:28:16Z	INFO	Invalid configuration file key	{"process": "storagenode-updater", "key": "storage2migration.interval"}
2026-03-16T19:28:16Z	INFO	Invalid configuration file key	{"process": "storagenode-updater", "key": "storage2.database-dir"}
2026-03-16T19:28:16Z	INFO	Invalid configuration file key	{"process": "storagenode-updater", "key": "server.private-address"}
2026-03-16T19:28:16Z	INFO	Invalid configuration file key	{"process": "storagenode-updater", "key": "healthcheck.details"}
2026-03-16T19:28:16Z	INFO	Anonymized tracing enabled	{"process": "storagenode-updater"}
2026-03-16T19:28:16Z	INFO	Running on version	{"process": "storagenode-updater", "service": "storagenode-updater", "version": "v1.148.3"}
2026-03-16T19:28:16Z	INFO	Downloading versions.	{"process": "storagenode-updater", "server_address": "https://version.storj.io"}
2026-03-16T19:28:16Z	INFO	Configuration loaded	{"process": "storagenode", "location": "/app/config/config.yaml"}
2026-03-16T19:28:16Z	INFO	Anonymized tracing enabled	{"process": "storagenode"}
2026-03-16T19:28:16Z	INFO	Operator email	{"process": "storagenode", "address": "walter1@magenta.de"}
2026-03-16T19:28:16Z	INFO	Operator wallet	{"process": "storagenode", "address": "0xba6CFA55a0fCF2e399e3AbA65dBC91d11Cb5E292"}
2026-03-16T19:28:16Z	INFO	server	kernel support for server-side tcp fast open remains disabled.	{"process": "storagenode"}
2026-03-16T19:28:16Z	INFO	server	enable with: sysctl -w net.ipv4.tcp_fastopen=3	{"process": "storagenode"}
2026-03-16T19:28:16Z	INFO	hashstore	loaded hint file	{"process": "storagenode", "satellite": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "store": "s0", "path": "config/storage/hashstore/121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6/s0/meta/hint-000000000000028b", "writable": [846, 832, 848, 77, 847, 826, 829, 845], "largest": 848, "skip": false}
2026-03-16T19:28:16Z	INFO	hashstore	unclean shutdown detected: reconciling logs	{"process": "storagenode", "satellite": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "store": "s0"}
2026-03-16T19:28:16Z	INFO	Current binary version	{"process": "storagenode-updater", "service": "storagenode", "version": "v1.148.3"}
2026-03-16T19:28:16Z	INFO	Version is up to date	{"process": "storagenode-updater", "service": "storagenode"}
2026-03-16T19:28:16Z	INFO	Current binary version	{"process": "storagenode-updater", "service": "storagenode-updater", "version": "v1.148.3"}
2026-03-16T19:28:16Z	INFO	Version is up to date	{"process": "storagenode-updater", "service": "storagenode-updater"}
2026-03-16T19:28:17Z	INFO	hashstore	loaded hint file	{"process": "storagenode", "satellite": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "store": "s1", "path": "config/storage/hashstore/121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6/s1/meta/hint-00000000000001eb", "writable": [625, 628, 627], "largest": 628, "skip": false}
2026-03-16 19:28:17,010 INFO success: processes-exit-eventlistener entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2026-03-16 19:28:17,010 INFO success: storagenode entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2026-03-16 19:28:17,010 INFO success: storagenode-updater entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2026-03-16T19:28:17Z	INFO	hashstore	unclean shutdown detected: reconciling logs	{"process": "storagenode", "satellite": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "store": "s1"}
2026-03-16T19:28:17Z	INFO	hashstore	hashstore opened successfully	{"process": "storagenode", "satellite": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "open_time": "1.634638799s", "logs_skipped": 126, "logs_matched": 11, "logs_mismatched": 0}
2026-03-16T19:28:17Z	INFO	hashstore	loaded hint file	{"process": "storagenode", "satellite": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "store": "s0", "path": "config/storage/hashstore/12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S/s0/meta/hint-0000000000000142", "writable": [], "largest": 0, "skip": false}
2026-03-16T19:28:25Z	ERROR	failure during run	{"process": "storagenode", "error": "Failed to create storage node peer: hashstore: read config/storage/hashstore/12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S/s0/meta/hashtbl-0000000000000145: input/output error\n\tstorj.io/storj/storagenode/hashstore.(*roBigPageCache).ReadRecord:649\n\tstorj.io/storj/storagenode/hashstore.(*HashTbl).Range:320\n\tstorj.io/storj/storagenode/hashstore.(*HashTbl).loadEntries:264\n\tstorj.io/storj/storagenode/hashstore.OpenHashTbl:176\n\tstorj.io/storj/storagenode/hashstore.OpenTable:120\n\tstorj.io/storj/storagenode/hashstore.NewStore:261\n\tstorj.io/storj/storagenode/hashstore.New:110\n\tstorj.io/storj/storagenode/piecestore.(*HashStoreBackend).getDB:272\n\tstorj.io/storj/storagenode/piecestore.NewHashStoreBackend:122\n\tstorj.io/storj/storagenode.New:607\n\tmain.cmdRun:84\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.InitBeforeExecute.func1.2:389\n\tstorj.io/common/process.InitBeforeExecute.func1:407\n\tgithub.com/spf13/cobra.(*Command).execute:985\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1117\n\tgithub.com/spf13/cobra.(*Command).Execute:1041\n\tstorj.io/common/process.ExecWithCustomOptions:115\n\tmain.main:34\n\truntime.main:285", "errorVerbose": "Failed to create storage node peer: hashstore: read config/storage/hashstore/12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S/s0/meta/hashtbl-0000000000000145: input/output error\n\tstorj.io/storj/storagenode/hashstore.(*roBigPageCache).ReadRecord:649\n\tstorj.io/storj/storagenode/hashstore.(*HashTbl).Range:320\n\tstorj.io/storj/storagenode/hashstore.(*HashTbl).loadEntries:264\n\tstorj.io/storj/storagenode/hashstore.OpenHashTbl:176\n\tstorj.io/storj/storagenode/hashstore.OpenTable:120\n\tstorj.io/storj/storagenode/hashstore.NewStore:261\n\tstorj.io/storj/storagenode/hashstore.New:110\n\tstorj.io/storj/storagenode/piecestore.(*HashStoreBackend).getDB:272\n\tstorj.io/storj/storagenode/piecestore.NewHashStoreBackend:122\n\tstorj.io/storj/storagenode.New:607\n\tmain.cmdRun:84\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.InitBeforeExecute.func1.2:389\n\tstorj.io/common/process.InitBeforeExecute.func1:407\n\tgithub.com/spf13/cobra.(*Command).execute:985\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1117\n\tgithub.com/spf13/cobra.(*Command).Execute:1041\n\tstorj.io/common/process.ExecWithCustomOptions:115\n\tmain.main:34\n\truntime.main:285\n\tmain.cmdRun:86\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.InitBeforeExecute.func1.2:389\n\tstorj.io/common/process.InitBeforeExecute.func1:407\n\tgithub.com/spf13/cobra.(*Command).execute:985\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1117\n\tgithub.com/spf13/cobra.(*Command).Execute:1041\n\tstorj.io/common/process.ExecWithCustomOptions:115\n\tmain.main:34\n\truntime.main:285"}
	main.cmdRun:84
	main.main:34
	runtime.main:285
How to fix this error and node?
Thanks and kind regards,
try to check disk for errors. does this disk accessible at all?
Yeah I can access the disk and did e2fsck, as already mentioned. So it is not completely gone yet.
Well, the extent of damage is larger than what your filesystem tools checked and fixed obviously. Depending on how you ran the fsck (did you provide -c flag?) it either did not relocate bad sectors or your disks death is being accelerated. Copy what you can to a new disk, accept data loss. There is nothing else to do.
I’m curious what model is the disk that it fails in such a catastrophic way. Post smartctl dump for it. (Or if it is Seagate — farm)
I just provided -fy. Now I reran e2fsck with
e2fsck -cfy /dev/sdN1
It’s a WDC HC560 WUH722020BLE6L4 20 TB from 2023 July. Sooner or later every drive will kinda fail, I’m pretty sure. This one lasted ~2,5 Years.
Edit: But yeah it is still throwing the same error message after -cfy. Do you think the drive is kinda defect?
That would be an understatement :slight_smile:. 2.5 years is very little time for a drive. Yes, it was definitely defective. You may be able to replace it under warranty (it’s 5 years for that drive).
Show output from smartctl -x /dev/<yourdisk>
The rsync to a new drive is already running. Will provide the smartctl after it’s been finished. Hopefully the node just runs again after the transplantation, with some data loss likely.
You don’t have to wait, smartctl -x talks to controller, it won’t interfere with your rsync. Don’t forget to tell rsync to --ignore-errors.
If you use hashstore, however, rsync is a wrong tool, you want to copy logs, even if it’s going to be corrupted in the middle. What you should do instead, is:
  1. Stop node
  2. run fsck again,
  3. unmount the filesystem
  4. connect a new disk, and do
    dd if=/dev/<baddisk> of=/dev/<gooddisk> bs=1M conv=noerror,sync
    Note conv here. dd with copy data and pad bad sectors
  5. Restart the node on the new disk.
It will be much faster than your rsync shenanigans, will prevent further damage, and corrupted logs will still preserve data that is intact.
Yeah rsync is kinda annoying. When it finds a bad block or sector it keeps retrying in an endless loop. So now I’m backing up the full disk with ddrescue. Similar to dd but with more options and smartness. dd is a kinda complete dumb tool.
The 197 Current_Pending_Sector is kinda huge with 14080 in smartctl -x /dev/<yourdisk>
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x80) Offline data collection activity
                                        was never started.
                                        Auto Offline Data Collection: Enabled.
Self-test execution status:      (   0) The previous self-test routine completed
                                        without error or no self-test has ever
                                        been run.
Total time to complete Offline
data collection:                (  101) seconds.
capabilities:                    (0x5b) SMART execute Offline immediate.
                                        Auto Offline data collection on/off support.
                                        Suspend Offline collection upon new
                                        command.
                                        Offline surface scan supported.
                                        Self-test supported.
                                        No Conveyance Self-test supported.
                                        Selective Self-test supported.
SMART capabilities:            (0x0003) Saves SMART data before entering
                                        power-saving mode.
                                        Supports SMART auto save timer.
Error logging capability:        (0x01) Error logging supported.
                                        General Purpose Logging supported.
Short self-test routine
recommended polling time:        (   2) minutes.
Extended self-test routine
recommended polling time:        (2413) minutes.
SCT capabilities:              (0x003d) SCT Status supported.
                                        SCT Error Recovery Control supported.
                                        SCT Feature Control supported.
                                        SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAGS    VALUE WORST THRESH FAIL RAW_VALUE
  1 Raw_Read_Error_Rate     PO-R--   100   100   001    -    0
  2 Throughput_Performance  P-S---   148   148   054    -    50
  3 Spin_Up_Time            POS---   086   086   001    -    282 (Average 313)
  4 Start_Stop_Count        -O--C-   100   100   000    -    47
  5 Reallocated_Sector_Ct   PO--CK   095   095   001    -    0
  7 Seek_Error_Rate         PO-R--   100   100   001    -    0
  8 Seek_Time_Performance   P-S---   140   140   020    -    15
  9 Power_On_Hours          -O--C-   098   098   000    -    23398
 10 Spin_Retry_Count        PO--C-   100   100   001    -    0
 12 Power_Cycle_Count       -O--CK   100   100   000    -    47
 22 Unknown_Attribute       PO---K   100   100   025    -    6553700
 90 Unknown_Attribute       P---CK   100   100   001    -    283467841536
192 Power-Off_Retract_Count -O--CK   100   100   000    -    893
193 Load_Cycle_Count        -O--C-   100   100   000    -    893
194 Temperature_Celsius     -O----   060   060   000    -    35 (Min/Max 16/48)
196 Reallocated_Event_Count -O--CK   100   100   000    -    0
197 Current_Pending_Sector  -O---K   100   100   000    -    14080
198 Offline_Uncorrectable   ---R--   100   100   000    -    0
199 UDMA_CRC_Error_Count    -O-R--   100   100   000    -    0
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
                            |||____ S speed/performance
                            ||_____ O updated online
                            |______ P prefailure warning
General Purpose Log Directory Version 1
SMART           Log Directory Version 1 [multi-sector log support]
Address    Access  R/W   Size  Description
0x00       GPL,SL  R/O      1  Log Directory
0x01           SL  R/O      1  Summary SMART error log
0x02           SL  R/O      1  Comprehensive SMART error log
0x03       GPL     R/O      1  Ext. Comprehensive SMART error log
0x04       GPL     R/O    256  Device Statistics log
0x04       SL      R/O    255  Device Statistics log
0x06           SL  R/O      1  SMART self-test log
0x07       GPL     R/O      1  Extended self-test log
0x08       GPL     R/O      2  Power Conditions log
0x09           SL  R/W      1  Selective self-test log
0x0c       GPL     R/O  17579  Pending Defects log
0x10       GPL     R/O      1  NCQ Command Error log
0x11       GPL     R/O      1  SATA Phy Event Counters log
0x12       GPL     R/O      1  SATA NCQ Non-Data log
0x13       GPL     R/O      1  SATA NCQ Send and Receive log
0x15       GPL     R/W      1  Rebuild Assist log
0x21       GPL     R/O      1  Write stream error log
0x22       GPL     R/O      1  Read stream error log
0x24       GPL     R/O    256  Current Device Internal Status Data log
0x25       GPL     R/O    256  Saved Device Internal Status Data log
0x2f       GPL     -        1  Set Sector Configuration
0x30       GPL,SL  R/O      9  IDENTIFY DEVICE data log
0x80-0x9f  GPL,SL  R/W     16  Host vendor specific log
0xb7           SL  VS       1  Device vendor specific log
0xd8-0xd9  GPL,SL  VS       1  Device vendor specific log
0xe0       GPL,SL  R/W      1  SCT Command/Status
0xe1       GPL,SL  R/W      1  SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (1 sectors)
Device Error Count: 58795 (device log contains only the most recent 4 errors)
        CR     = Command Register
        FEATR  = Features Register
        COUNT  = Count (was: Sector Count) Register
        LBA_48 = Upper bytes of LBA High/Mid/Low Registers ]  ATA-8
        LH     = LBA High (was: Cylinder High) Register    ]   LBA
        LM     = LBA Mid (was: Cylinder Low) Register      ] Register
        LL     = LBA Low (was: Sector Number) Register     ]
        DV     = Device (was: Device/Head) Register
        DC     = Device Control Register
        ER     = Error register
        ST     = Status register
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 58795 [2] occurred at disk power-on lifetime: 23398 hours (974 days + 22 hours)
  When the command that caused the error occurred, the device was active or idle.
  After command completion occurred, registers were:
  ER -- ST COUNT  LBA_48  LH LM LL DV DC
  40 -- 43 00 00 00 00 00 00 00 00 00 00  Error: UNC at LBA = 0x00000000 = 0
  Commands leading to the command that caused the error were:
  CR FEATR COUNT  LBA_48  LH LM LL DV DC  Powered_Up_Time  Command/Feature_Name
  60 00 08 00 10 00 00 b7 e0 48 00 40 08     13:46:56.698  READ FPDMA QUEUED
  47 00 00 00 01 00 00 00 00 00 00 a0 08     13:46:53.466  READ LOG DMA EXT
  47 00 00 00 01 00 00 00 00 08 30 a0 08     13:46:53.463  READ LOG DMA EXT
  47 00 00 00 01 00 00 00 00 00 30 a0 08     13:46:53.459  READ LOG DMA EXT
  47 00 00 00 01 00 00 00 00 00 00 a0 08     13:46:53.459  READ LOG DMA EXT
Error 58794 [1] occurred at disk power-on lifetime: 23398 hours (974 days + 22 hours)
  60 00 08 00 38 00 00 b7 e0 48 00 40 08     13:46:53.340  READ FPDMA QUEUED
  60 00 08 00 30 00 00 b7 e0 47 f8 40 08     13:46:50.150  READ FPDMA QUEUED
  60 00 08 00 28 00 00 b7 e0 47 f0 40 08     13:46:50.150  READ FPDMA QUEUED
  60 00 08 00 20 00 00 b7 e0 47 e8 40 08     13:46:50.150  READ FPDMA QUEUED
  60 00 08 00 18 00 00 b7 e0 47 e0 40 08     13:46:50.150  READ FPDMA QUEUED
Error 58793 [0] occurred at disk power-on lifetime: 23397 hours (974 days + 21 hours)
  60 00 08 00 40 00 00 a9 b8 4a 28 40 08     13:30:29.040  READ FPDMA QUEUED
  47 00 00 00 01 00 00 00 00 00 00 a0 08     13:30:25.891  READ LOG DMA EXT
  47 00 00 00 01 00 00 00 00 08 30 a0 08     13:30:25.887  READ LOG DMA EXT
  47 00 00 00 01 00 00 00 00 00 30 a0 08     13:30:25.884  READ LOG DMA EXT
  47 00 00 00 01 00 00 00 00 00 00 a0 08     13:30:25.884  READ LOG DMA EXT
Error 58792 [3] occurred at disk power-on lifetime: 23397 hours (974 days + 21 hours)
  60 00 08 00 50 00 00 a9 b8 4a 28 40 08     13:30:25.782  READ FPDMA QUEUED
  47 00 00 00 01 00 00 00 00 00 00 a0 08     13:30:22.611  READ LOG DMA EXT
  47 00 00 00 01 00 00 00 00 08 30 a0 08     13:30:22.607  READ LOG DMA EXT
  47 00 00 00 01 00 00 00 00 00 30 a0 08     13:30:22.604  READ LOG DMA EXT
  47 00 00 00 01 00 00 00 00 00 00 a0 08     13:30:22.604  READ LOG DMA EXT
SMART Extended Self-test Log Version: 1 (1 sectors)
No self-tests have been logged.  [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 1
 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
SCT Status Version:                  3
SCT Version (vendor specific):       256 (0x0100)
Device State:                        Active (0)
Current Temperature:                    35 Celsius
Power Cycle Min/Max Temperature:     34/36 Celsius
Lifetime    Min/Max Temperature:     16/48 Celsius
Under/Over Temperature Limit Count:   0/0
SMART Status:                        0xc24f (PASSED)
Minimum supported ERC Time Limit:    65 (6,5 seconds)
SCT Temperature History Version:     2
Temperature Sampling Period:         1 minute
Temperature Logging Interval:        1 minute
Min/Max recommended Temperature:      0/60 Celsius
Min/Max Temperature Limit:           -40/70 Celsius
Temperature History Size (Index):    128 (93)
Index    Estimated Time   Temperature Celsius
  94    2026-03-17 11:01    35  ****************
 ...    ..( 27 skipped).    ..  ****************
 122    2026-03-17 11:29    35  ****************
 123    2026-03-17 11:30    36  *****************
 124    2026-03-17 11:31    35  ****************
 125    2026-03-17 11:32    36  *****************
 126    2026-03-17 11:33    35  ****************
 127    2026-03-17 11:34    35  ****************
   0    2026-03-17 11:35    36  *****************
   1    2026-03-17 11:36    35  ****************
 ...    ..(  2 skipped).    ..  ****************
   4    2026-03-17 11:39    35  ****************
   5    2026-03-17 11:40    36  *****************
   6    2026-03-17 11:41    36  *****************
   7    2026-03-17 11:42    36  *****************
   8    2026-03-17 11:43    35  ****************
   9    2026-03-17 11:44    35  ****************
  10    2026-03-17 11:45    36  *****************
  11    2026-03-17 11:46    35  ****************
  12    2026-03-17 11:47    35  ****************
  13    2026-03-17 11:48    35  ****************
  14    2026-03-17 11:49    36  *****************
  15    2026-03-17 11:50    35  ****************
  16    2026-03-17 11:51    35  ****************
  17    2026-03-17 11:52    36  *****************
  18    2026-03-17 11:53    35  ****************
  19    2026-03-17 11:54    36  *****************
 ...    ..(  3 skipped).    ..  *****************
  23    2026-03-17 11:58    36  *****************
  24    2026-03-17 11:59    35  ****************
  25    2026-03-17 12:00    35  ****************
  26    2026-03-17 12:01    36  *****************
  27    2026-03-17 12:02    36  *****************
  28    2026-03-17 12:03    35  ****************
  29    2026-03-17 12:04    35  ****************
  30    2026-03-17 12:05    35  ****************
  31    2026-03-17 12:06    36  *****************
  32    2026-03-17 12:07    35  ****************
  33    2026-03-17 12:08    36  *****************
  34    2026-03-17 12:09    36  *****************
  35    2026-03-17 12:10    35  ****************
  38    2026-03-17 12:13    35  ****************
  39    2026-03-17 12:14    36  *****************
  40    2026-03-17 12:15    35  ****************
  41    2026-03-17 12:16    35  ****************
  42    2026-03-17 12:17    36  *****************
  43    2026-03-17 12:18    35  ****************
  47    2026-03-17 12:22    35  ****************
  48    2026-03-17 12:23    36  *****************
  49    2026-03-17 12:24    35  ****************
  50    2026-03-17 12:25    35  ****************
  51    2026-03-17 12:26    35  ****************
  52    2026-03-17 12:27    36  *****************
 ...    ..(  6 skipped).    ..  *****************
  59    2026-03-17 12:34    36  *****************
  60    2026-03-17 12:35    35  ****************
  61    2026-03-17 12:36    35  ****************
  62    2026-03-17 12:37    36  *****************
  63    2026-03-17 12:38    35  ****************
  64    2026-03-17 12:39    36  *****************
  65    2026-03-17 12:40    35  ****************
  66    2026-03-17 12:41    36  *****************
  67    2026-03-17 12:42    35  ****************
  68    2026-03-17 12:43    36  *****************
  69    2026-03-17 12:44    35  ****************
  72    2026-03-17 12:47    35  ****************
  73    2026-03-17 12:48    36  *****************
  74    2026-03-17 12:49    35  ****************
  78    2026-03-17 12:53    35  ****************
  79    2026-03-17 12:54    36  *****************
  80    2026-03-17 12:55    35  ****************
  81    2026-03-17 12:56    35  ****************
  82    2026-03-17 12:57    36  *****************
  83    2026-03-17 12:58    35  ****************
 ...    ..(  9 skipped).    ..  ****************
  93    2026-03-17 13:08    35  ****************
SCT Error Recovery Control:
           Read: Disabled
          Write: Disabled
Device Statistics (GP Log 0x04)
Page  Offset Size        Value Flags Description
0x01  =====  =               =  ===  == General Statistics (rev 1) ==
0x01  0x008  4              47  ---  Lifetime Power-On Resets
0x01  0x010  4           23398  ---  Power-on Hours
0x01  0x018  6    345125374760  ---  Logical Sectors Written
0x01  0x020  6      3398901753  ---  Number of Write Commands
0x01  0x028  6    393239255251  ---  Logical Sectors Read
0x01  0x030  6      5043834519  ---  Number of Read Commands
0x01  0x038  6     84233696650  ---  Date and Time TimeStamp
0x03  =====  =               =  ===  == Rotating Media Statistics (rev 1) ==
0x03  0x008  4           23394  ---  Spindle Motor Power-on Hours
0x03  0x010  4           23393  ---  Head Flying Hours
0x03  0x018  4             893  ---  Head Load Events
0x03  0x020  4               0  ---  Number of Reallocated Logical Sectors
0x03  0x028  4           70364  ---  Read Recovery Attempts
0x03  0x030  4              29  ---  Number of Mechanical Start Failures
0x04  =====  =               =  ===  == General Errors Statistics (rev 1) ==
0x04  0x008  4           58795  ---  Number of Reported Uncorrectable Errors
0x04  0x010  4              19  ---  Resets Between Cmd Acceptance and Completion
0x05  =====  =               =  ===  == Temperature Statistics (rev 1) ==
0x05  0x008  1              35  ---  Current Temperature
0x05  0x010  1              35  N--  Average Short Term Temperature
0x05  0x018  1              33  N--  Average Long Term Temperature
0x05  0x020  1              48  ---  Highest Temperature
0x05  0x028  1              16  ---  Lowest Temperature
0x05  0x030  1              45  N--  Highest Average Short Term Temperature
0x05  0x038  1              25  N--  Lowest Average Short Term Temperature
0x05  0x040  1              41  N--  Highest Average Long Term Temperature
0x05  0x048  1              25  N--  Lowest Average Long Term Temperature
0x05  0x050  4               0  ---  Time in Over-Temperature
0x05  0x058  1              60  ---  Specified Maximum Operating Temperature
0x05  0x060  4               0  ---  Time in Under-Temperature
0x05  0x068  1               0  ---  Specified Minimum Operating Temperature
0x06  =====  =               =  ===  == Transport Statistics (rev 1) ==
0x06  0x008  4             117  ---  Number of Hardware Resets
0x06  0x010  4              15  ---  Number of ASR Events
0x06  0x018  4               0  ---  Number of Interface CRC Errors
0xff  =====  =               =  ===  == Vendor Specific Statistics (rev 1) ==
                                |||_ C monitored condition met
                                ||__ D supports DSN
                                |___ N normalized value
Pending Defects log (GP Log 0x0c)
Index                LBA    Hours
    0         1848037848    23384
    1         1848037849    23384
    2         1848037850    23384
    3         1848037851    23384
    4         1848037852    23384
    5         1848037853    23384
    6         1848037854    23384
    7         1848037855    23384
    8         1848037856    23384
    9         1848037857    23384
   10         1848037858    23384
   11         1848037859    23384
   12         1848037860    23384
   13         1848037861    23384
   14         1848037862    23384
   15         1848037863    23384
   16         1848037888    23384
   17         1848037889    23384
   18         1848037890    23384
   19         1848037891    23384
   20         1848037892    23384
   21         1848037893    23384
   22         1848037894    23384
   23         1848037895    23384
   24         1848037896    23384
   25         1848037897    23384
   26         1848037898    23384
   27         1848037899    23384
   28         1848037900    23384
   29         1848037901    23384
   30         1848037902    23384
... (14049 entries not shown)
SATA Phy Event Counters (GP Log 0x11)
ID      Size     Value  Description
0x0001  2            0  Command failed due to ICRC error
0x0002  2            0  R_ERR response for data FIS
0x0003  2            0  R_ERR response for device-to-host data FIS
0x0004  2            0  R_ERR response for host-to-device data FIS
0x0005  2            0  R_ERR response for non-data FIS
0x0006  2            0  R_ERR response for device-to-host non-data FIS
0x0007  2            0  R_ERR response for host-to-device non-data FIS
0x0008  2            0  Device-to-host non-data FIS retries
0x0009  2            3  Transition from drive PhyRdy to drive PhyNRdy
0x000a  2            3  Device-to-host register FISes sent due to a COMRESET
0x000b  2            0  CRC errors within host-to-device FIS
0x000d  2            0  Non-CRC errors within host-to-device FIS
Maybe but… I tried ddrescue several times on dying disks. Even after days of work it NEVER rescued any additional data compared to rsync. Therefore rsync is still my tool of choice.
This applies to ZFS, other file systems might be different.
You don’t want disk to keep retrying indefinitely. You want it to give up asap. Configure it to the smallest supported number (its timeout in deciseconds), for this drive it’s 65. You can do it while the process is going.
I’m wondering what caused the disk to fail this way? Was the drive kicked while spinning? WD does not include shock sensors so we will never know.
Can you explain what this error message is? And a kinda detailed guide how to configure the number to it’s lowest number?
This is error recovery control. Controls how much time is firmware allowed to spend trying to recover data before returning an error. Disabled means no limit. You don’t want it to keep recovering, you want it to skip and move on as soon as possible.
Minimum for your disk, according to manual, is 6.5 seconds (see table 55 here https://documents.westerndigital.com/content/dam/doc-library/en_us/assets/public/western-digital/product/data-center-drives/ultrastar-dc-hc500-series/product-manual-ultrastar-dc-hc560-sata-oem-spec.pdf).
You can set it like so:
smartctl -l scterc,65,65 /dev/<yourdisk>
and verify
smartctl -l scterc /dev/<yourdisk>
Thanks alot, got it now to 6.5 seconds:
Wow! This is gold. Why the heck the default is infinite? What could it recover in an hour, if it can’t do it in a few ms or seconds? Isn’t like the disk has autoregen.
Because defaults are prioritizing data recovery. When you are using these disks in the array, you are expected to configure them to fail early instead, because data recovery is now handled at the array level. But vendor does not know how are you going to be using the drive, so defaults to safest setting.
If probability to read data correctly is 1% then trying 100 times has a reasonable chance to succeed. It’s not black and white — it’s an analog device, no two head flybys are the same.
After all this waiting ddrescue finished today successfully.
I also had to change the UUID and then rewrite all the superblocks. Now it seems to be working on the new drive.
But there are alot of warnings:
WARN    hashstore       mismatched log tail     {"process": "storagenode", "satellite": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "store": "s0", "id": 2845, "path": "config/storage/hashstore/12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S/s0/1d/log-0000000000000b1d-00000000", "table": [{"Key":"DE4UHEI7P6KAL265NUG3TINY3TYPMYVJ3KSBPBYPK25GEYGCBEVQ","Offset":1073658176,"Log":2845,"Length":108288,"Created":20393,"Expires":0},{"Key":"DERA3RRAB3HKHBGXCWV7X4HBBAGLQQPKBFOIH5DA7Y2PBNVKNE6Q","Offset":1073591296,"Log":2845,"Length":66816,"Created":20393,"Expires":0},{"Key":"DEWERCYEG5BBPW3JAS3WBM4DELUPB43PZISC3OZU2C5UREE3Q6LA","Offset":1073553024,"Log":2845,"Length":37120,"Created":20393,"Expires":0},{"Key":"DEY7N77DMBRBRDF4KDTF3ZYHQBN677ZH4N3JT5QV4N6BIRTCZSTQ","Offset":1073370944,"Log":2845,"Length":182016,"Created":20393,"Expires":0},{"Key":"DEVGEJPGTT5B5NH3ROH2D3ZMQDUJ7657C5ELPUEXTPXMBRTDY3TQ","Offset":1072725248,"Log":2845,"Length":645632,"Created":20393,"Expires":0}], "log": [{"Key":"DE4UHEI7P6KAL265NUG3TINY3TYPMYVJ3KSBPBYPK25GEYGCBEVQ","Offset":1073658176,"Log":2845,"Length":108288,"Created":20393,"Expires":0},{"Key":"DERA3RRAB3HKHBGXCWV7X4HBBAGLQQPKBFOIH5DA7Y2PBNVKNE6Q","Offset":1073591296,"Log":2845,"Length":66816,"Created":20393,"Expires":0},{"Key":"DEQRL775SKCHGTUSYD5O6P2BC6XKQQFBNULHRPECYZBABSMH5H6Q","Offset":1073590208,"Log":2845,"Length":1024,"Created":20393,"Expires":0},{"Key":"DEWERCYEG5BBPW3JAS3WBM4DELUPB43PZISC3OZU2C5UREE3Q6LA","Offset":1073553024,"Log":2845,"Length":37120,"Created":20393,"Expires":0},{"Key":"DEY7N77DMBRBRDF4KDTF3ZYHQBN677ZH4N3JT5QV4N6BIRTCZSTQ","Offset":1073370944,"Log":2845,"Length":182016,"Created":20393,"Expires":0}]}
2026-03-21T15:11:47Z    WARN    hashstore       mismatched log tail     {"process": "storagenode", "satellite": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "store": "s0", "id": 5149, "path": "config/storage/hashstore/12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S/s0/1d/log-000000000000141d-00000000", "table": [{"Key":"QL4VRBK72NI7OGC45UFFGN4LCEX5YZJ5LZ3DZAK5NF7LNMNCVIAA","Offset":1073448512,"Log":5149,"Length":725504,"Created":20350,"Expires":0},{"Key":"V653ZDPAVOOTUMDTV7YKTPVYWCWJC4AQCDHPAUYSKXX3DMENNX2A","Offset":1073266432,"Log":5149,"Length":182016,"Created":20350,"Expires":0},{"Key":"D327UDS7LI2FXBFS57MZSUQP6GYFYDTMBZINU43GSJLBZSZWYKTQ","Offset":1073069440,"Log":5149,"Length":182016,"Created":20350,"Expires":0},{"Key":"SQF6WBQ6Q5G4BRH7VCQ2HSH4AC6VZBCDJIOPB2AB2VGJZ3ROEY7Q","Offset":1072947264,"Log":5149,"Length":122112,"Created":20350,"Expires":0},{"Key":"BDAQXCWMAZ7W5OUEG25DIGCQBHXVT7I3HXUQ6LR3GWWWQYWILS6A","Offset":1072934144,"Log":5149,"Length":13056,"Created":20350,"Expires":0}], "log": [{"Key":"QL4VRBK72NI7OGC45UFFGN4LCEX5YZJ5LZ3DZAK5NF7LNMNCVIAA","Offset":1073448512,"Log":5149,"Length":725504,"Created":20350,"Expires":0},{"Key":"V653ZDPAVOOTUMDTV7YKTPVYWCWJC4AQCDHPAUYSKXX3DMENNX2A","Offset":1073266432,"Log":5149,"Length":182016,"Created":20350,"Expires":0},{"Key":"VRP6GRBYSL7EF42N63XYPG5HVEXTHPDMKFFHZLZPW26FMDRJS5QQ","Offset":1073251520,"Log":5149,"Length":14848,"Created":20350,"Expires":0},{"Key":"D327UDS7LI2FXBFS57MZSUQP6GYFYDTMBZINU43GSJLBZSZWYKTQ","Offset":1073069440,"Log":5149,"Length":182016,"Created":20350,"Expires":0},{"Key":"SQF6WBQ6Q5G4BRH7VCQ2HSH4AC6VZBCDJIOPB2AB2VGJZ3ROEY7Q","Offset":1072947264,"Log":5149,"Length":122112,"Created":20350,"Expires":0}]}
2026-03-21T15:12:06Z    WARN    hashstore       mismatched log tail     {"process": "storagenode", "satellite": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "store": "s0", "id": 3102, "path": "config/storage/hashstore/12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S/s0/1e/log-0000000000000c1e-00000000", "table": [{"Key":"VLXHFU6GVL7YDLSOSK2B44ZSELHOURAHBHHIRYS4UE62CU22LUQA","Offset":1073405056,"Log":3102,"Length":2174976,"Created":20338,"Expires":0},{"Key":"LC47KBQCN5MYUQYJ37ICZ4MHGORRB5HX3EONHJF5OQW5IOI2BCUA","Offset":1073393216,"Log":3102,"Length":11776,"Created":20338,"Expires":0},{"Key":"QN3RGEYR44BRX24CR4KIID36K6XE5RBFRCTMYSSRPNPOPY2KJKZQ","Offset":1073211136,"Log":3102,"Length":182016,"Created":20338,"Expires":0},{"Key":"JRIAPDSB2ODRSJ2MN3ZRBAVPDOPBUQLSVTLYQNIIAIWJ7NMSWF4A","Offset":1070891200,"Log":3102,"Length":2319872,"Created":20338,"Expires":0},{"Key":"ZJ2SDYLA242O63DSKHNJ3BQ4L2KHS3X7JD65FM4JCGD3YNPHT5SQ","Offset":1070858048,"Log":3102,"Length":32000,"Created":20338,"Expires":0}], "log": [{"Key":"VLXHFU6GVL7YDLSOSK2B44ZSELHOURAHBHHIRYS4UE62CU22LUQA","Offset":1073405056,"Log":3102,"Length":2174976,"Created":20338,"Expires":0},{"Key":"LC47KBQCN5MYUQYJ37ICZ4MHGORRB5HX3EONHJF5OQW5IOI2BCUA","Offset":1073393216,"Log":3102,"Length":11776,"Created":20338,"Expires":0},{"Key":"QN3RGEYR44BRX24CR4KIID36K6XE5RBFRCTMYSSRPNPOPY2KJKZQ","Offset":1073211136,"Log":3102,"Length":182016,"Created":20338,"Expires":0},{"Key":"JRIAPDSB2ODRSJ2MN3ZRBAVPDOPBUQLSVTLYQNIIAIWJ7NMSWF4A","Offset":1070891200,"Log":3102,"Length":2319872,"Created":20338,"Expires":0},{"Key":"HNVXPDNOQGWRFUP7W2QP2Z54P6VKDGJVCM3QSWD4WWIP243YPRKQ","Offset":1070890112,"Log":3102,"Length":1024,"Created":20338,"Expires":0}]}
2026-03-21T15:12:29Z    WARN    hashstore       mismatched log tail     {"process": "storagenode", "satellite": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "store": "s0", "id": 6174, "path": "config/storage/hashstore/12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S/s0/1e/log-000000000000181e-00000000", "table": [{"Key":"RZ2XH4HCJ3U45CU4QYKH4I5IEA7KPN7YJX6MXT4U4UAE72VJOIQQ","Offset":1072159808,"Log":6174,"Length":4096,"Created":20491,"Expires":0},{"Key":"BMKSRCX6HWTQWAMCL4VBKYUM74GE3DR77GHIPENFHH5U4XYLKZIQ","Offset":1072140032,"Log":6174,"Length":19712,"Created":20491,"Expires":0},{"Key":"ZZU5WZXTZGN26UN7DJWPCSJYK4Z422WXRLODA3PUDCAPUTNPYJUA","Offset":1069818752,"Log":6174,"Length":1280,"Created":20491,"Expires":0},{"Key":"HB4HQ7C6A6EQPJKDH2OB6RAALA62BNTF5BFLOVUQEXRYKOY54F4Q","Offset":1069455424,"Log":6174,"Length":363264,"Created":20491,"Expires":0},{"Key":"ECN3PILUDN5F3BSR4K3LUL455QBRZWOXSBHF2UW6VMKZ7TGXM25Q","Offset":1069454336,"Log":6174,"Length":1024,"Created":20491,"Expires":0}], "log": [{"Key":"BQIT75ZLLIYVV3XLB43LIOG3CHZC4DDUNKLP4QNYXQ6LG5F4OWLA","Offset":1072163968,"Log":6174,"Length":2319872,"Created":20491,"Expires":0},{"Key":"RZ2XH4HCJ3U45CU4QYKH4I5IEA7KPN7YJX6MXT4U4UAE72VJOIQQ","Offset":1072159808,"Log":6174,"Length":4096,"Created":20491,"Expires":0},{"Key":"BMKSRCX6HWTQWAMCL4VBKYUM74GE3DR77GHIPENFHH5U4XYLKZIQ","Offset":1072140032,"Log":6174,"Length":19712,"Created":20491,"Expires":0},{"Key":"763CKIOPGZ3ZDPPNDMH5TNBMFTWYNJWBSA7SZCIM6N27CV4GDZGQ","Offset":1069820096,"Log":6174,"Length":2319872,"Created":20491,"Expires":0},{"Key":"ZZU5WZXTZGN26UN7DJWPCSJYK4Z422WXRLODA3PUDCAPUTNPYJUA","Offset":1069818752,"Log":6174,"Length":1280,"Created":20491,"Expires":0}]}
2026-03-21T15:12:44Z    WARN    hashstore       mismatched log tail     {"process": "storagenode", "satellite": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "store": "s0", "id": 4640, "path": "config/storage/hashstore/12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S/s0/20/log-0000000000001220-00000000", "table": [{"Key":"PMAHZD4X7E2HXNAKEGX6Q4FF4DL753K22BH5NCNPCXRFISY3IO5A","Offset":1073664384,"Log":4640,"Length":363264,"Created":20398,"Expires":0},{"Key":"PMARCOJ32EINI3FDHY37W55UHVKAM4S5MLGLUKTD3DHRT6KPRGBQ","Offset":1073625856,"Log":4640,"Length":1024,"Created":20398,"Expires":0},{"Key":"PM37QJB6F6JXDNOMB3H4D5QXMI56GTZP4GLDRE7HXKRSNPX2HIYA","Offset":1073435072,"Log":4640,"Length":190720,"Created":20398,"Expires":0},{"Key":"PMF7YB3QXEMOWKYTOO2BXZN6SX6GTRRHU2PT3KOIKYADZZFX4O4Q","Offset":1073428352,"Log":4640,"Length":6656,"Created":20398,"Expires":0},{"Key":"PMVBB4HQN46SK66EP7USK5IJYFFZ2QBZXNTMCUEXFYGMN4F7GX3Q","Offset":1073426752,"Log":4640,"Length":1536,"Created":20398,"Expires":0}], "log": [{"Key":"PMAHZD4X7E2HXNAKEGX6Q4FF4DL753K22BH5NCNPCXRFISY3IO5A","Offset":1073664384,"Log":4640,"Length":363264,"Created":20398,"Expires":0},{"Key":"PM6OVZOGT2SQPPNCWBN3FKQHDOODBIO4LX4VLMOHOP2BQEJLFLVA","Offset":1073626944,"Log":4640,"Length":37376,"Created":20398,"Expires":0},{"Key":"PMARCOJ32EINI3FDHY37W55UHVKAM4S5MLGLUKTD3DHRT6KPRGBQ","Offset":1073625856,"Log":4640,"Length":1024,"Created":20398,"Expires":0},{"Key":"PM37QJB6F6JXDNOMB3H4D5QXMI56GTZP4GLDRE7HXKRSNPX2HIYA","Offset":1073435072,"Log":4640,"Length":190720,"Created":20398,"Expires":0},{"Key":"PMF7YB3QXEMOWKYTOO2BXZN6SX6GTRRHU2PT3KOIKYADZZFX4O4Q","Offset":1073428352,"Log":4640,"Length":6656,"Created":20398,"Expires":0}]}
2026-03-21T15:13:20Z    WARN    hashstore       mismatched log tail     {"process": "storagenode", "satellite": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "store": "s0", "id": 5152, "path": "config/storage/hashstore/12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S/s0/20/log-0000000000001420-00000000", "table": [{"Key":"MXIALUNKKEEDERJNDK5F5R232OC35MH5UHUEIHNTFQNGM2IZRN6Q","Offset":1071432640,"Log":5152,"Length":2319872,"Created":20366,"Expires":0},{"Key":"BQQNFPURUK6G3DDB4BSNNWZOMK4O7WSKE3IQLXKEKKFWC6LPMWZQ","Offset":1071414912,"Log":5152,"Length":17664,"Created":20366,"Expires":0},{"Key":"XMGFDYH73UTFBRFQGUIIFN62C7BOUAGZZZ4H7QHZRCUFQJYO22CQ","Offset":1071357760,"Log":5152,"Length":57088,"Created":20366,"Expires":0},{"Key":"DACNZBZZYWURCDRS3L54D64KEVT2VEJCB5ITQ2AQIY33IH23VU5Q","Offset":1071290112,"Log":5152,"Length":67584,"Created":20366,"Expires":0},{"Key":"WTDKCAQN6I7Y5SINJ3GQJSCZZRRN2PJDS7TZCKJOBPFOKUJ4ALWA","Offset":1070678144,"Log":5152,"Length":19712,"Created":20366,"Expires":0}], "log": [{"Key":"MXIALUNKKEEDERJNDK5F5R232OC35MH5UHUEIHNTFQNGM2IZRN6Q","Offset":1071432640,"Log":5152,"Length":2319872,"Created":20366,"Expires":0},{"Key":"BQQNFPURUK6G3DDB4BSNNWZOMK4O7WSKE3IQLXKEKKFWC6LPMWZQ","Offset":1071414912,"Log":5152,"Length":17664,"Created":20366,"Expires":0},{"Key":"XMGFDYH73UTFBRFQGUIIFN62C7BOUAGZZZ4H7QHZRCUFQJYO22CQ","Offset":1071357760,"Log":5152,"Length":57088,"Created":20366,"Expires":0},{"Key":"DACNZBZZYWURCDRS3L54D64KEVT2VEJCB5ITQ2AQIY33IH23VU5Q","Offset":1071290112,"Log":5152,"Length":67584,"Created":20366,"Expires":0},{"Key":"KJ74PTONYNGIM67ZBTVTSJQV3ZK2622REXL2IYIYQ3KQ5CCG6GYA","Offset":1070697920,"Log":5152,"Length":592128,"Created":20366,"Expires":0}]}
2026-03-21T15:13:43Z    WARN    hashstore       mismatched log tail     {"process": "storagenode", "satellite": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "store": "s0", "id": 2338, "path": "config/storage/hashstore/12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S/s0/22/log-0000000000000922-00000000", "table": [{"Key":"UPU3YBG2XKBBXDKYSLVNFVEYM2I5EA6QSGMR5LFUGFRXR2GCOV4A","Offset":1073308480,"Log":2338,"Length":2319872,"Created":20336,"Expires":0},{"Key":"UXIZHXGD73GIAB6AVX7HV4LD4YLOBGH4PUSU2Y63NQM32QCYTGVA","Offset":1073208576,"Log":2338,"Length":99840,"Created":20336,"Expires":0},{"Key":"BWBKDFBHYCODULCMIFXUIZGAHHAWDUE7CNTDN2IVV6WJOSXWHDYA","Offset":1073026496,"Log":2338,"Length":182016,"Created":20336,"Expires":0},{"Key":"NI2R4CSOHCWE37VXSCMR5VBKOMCNYRP2JPVSLOTDX5B5DIC3TTHQ","Offset":1073025152,"Log":2338,"Length":1280,"Created":20336,"Expires":0},{"Key":"6R2BLYSWF6PS3ZEVSSXS4DKRV64KXNMMTU5ZP2MQTRWA54DU5QKA","Offset":1072639744,"Log":2338,"Length":1536,"Created":20336,"Expires":0}], "log": [{"Key":"UPU3YBG2XKBBXDKYSLVNFVEYM2I5EA6QSGMR5LFUGFRXR2GCOV4A","Offset":1073308480,"Log":2338,"Length":2319872,"Created":20336,"Expires":0},{"Key":"UXIZHXGD73GIAB6AVX7HV4LD4YLOBGH4PUSU2Y63NQM32QCYTGVA","Offset":1073208576,"Log":2338,"Length":99840,"Created":20336,"Expires":0},{"Key":"BWBKDFBHYCODULCMIFXUIZGAHHAWDUE7CNTDN2IVV6WJOSXWHDYA","Offset":1073026496,"Log":2338,"Length":182016,"Created":20336,"Expires":0},{"Key":"NI2R4CSOHCWE37VXSCMR5VBKOMCNYRP2JPVSLOTDX5B5DIC3TTHQ","Offset":1073025152,"Log":2338,"Length":1280,"Created":20336,"Expires":0},{"Key":"KR6J3K546LL3C7V6KTTYNIUKGS2XUZLX2OJTE4BJ3IMIDLBC7B5A","Offset":1072641344,"Log":2338,"Length":383744,"Created":20336,"Expires":0}]}
2026-03-21T15:13:59Z    WARN    hashstore       mismatched log tail     {"process": "storagenode", "satellite": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "store": "s0", "id": 4642, "path": "config/storage/hashstore/12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S/s0/22/log-0000000000001222-00000000", "table": [{"Key":"KWDCS7TBYZT5XYVMMOIG7HSWLV3ILNVMRSGSV6IW75PM5NZCEZ7Q","Offset":1071510144,"Log":4642,"Length":2295040,"Created":20389,"Expires":0},{"Key":"DBJI73SBIPA5WNCXKASQZACHPOHTOJIZBEE6JTRLYECWQQN5E5MQ","Offset":1071436544,"Log":4642,"Length":42240,"Created":20389,"Expires":0},{"Key":"MPHPYDSZUGPID6MROHVSMGMUHUXMF5MMGFLHNFGJESVVDRIYTKEA","Offset":1071329216,"Log":4642,"Length":107264,"Created":20389,"Expires":0},{"Key":"ODF5ODVOPSVDWGBI76ZYBW2SCP66VLIS2YIKFADZOE6VPOGHA5ZQ","Offset":1070951552,"Log":4642,"Length":377600,"Created":20389,"Expires":0},{"Key":"IQPEBYXRZBB5TNFMJ7WGCCKW4QDUCT6KUNDJS5HBCTWVJHN5UE7Q","Offset":1070769472,"Log":4642,"Length":182016,"Created":20389,"Expires":0}], "log": [{"Key":"KWDCS7TBYZT5XYVMMOIG7HSWLV3ILNVMRSGSV6IW75PM5NZCEZ7Q","Offset":1071510144,"Log":4642,"Length":2295040,"Created":20389,"Expires":0},{"Key":"ZNQ3AZRAIGGYOOAF5RAGCWTZV57HY7DAUG6CWFJUZYC46KM4TY7A","Offset":1071478848,"Log":4642,"Length":31232,"Created":20389,"Expires":0},{"Key":"DBJI73SBIPA5WNCXKASQZACHPOHTOJIZBEE6JTRLYECWQQN5E5MQ","Offset":1071436544,"Log":4642,"Length":42240,"Created":20389,"Expires":0},{"Key":"MPHPYDSZUGPID6MROHVSMGMUHUXMF5MMGFLHNFGJESVVDRIYTKEA","Offset":1071329216,"Log":4642,"Length":107264,"Created":20389,"Expires":0},{"Key":"ODF5ODVOPSVDWGBI76ZYBW2SCP66VLIS2YIKFADZOE6VPOGHA5ZQ","Offset":1070951552,"Log":4642,"Length":377600,"Created":20389,"Expires":0}]}
2026-03-21T15:14:15Z    WARN    hashstore       mismatched log tail     {"process": "storagenode", "satellite": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "store": "s0", "id": 2339, "path": "config/storage/hashstore/12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S/s0/23/log-0000000000000923-00000000", "table": [{"Key":"P25MRPQITOWJPJEZWXAJFOP6C22TIP6JYY72HDLLRTLERBUA5AKA","Offset":1073485568,"Log":2339,"Length":648704,"Created":20339,"Expires":0},{"Key":"5QAGPEAF2LWY3AHAIR6HVBLDK2VE4JHAFJ44QELW2KXXE3YWXVWQ","Offset":1073303488,"Log":2339,"Length":182016,"Created":20339,"Expires":0},{"Key":"27Y3HXCP5R2JGJANPS2AZ35ZJPSVILFHHQBHRFXJKLFBWQJRGYYA","Offset":1072940160,"Log":2339,"Length":363264,"Created":20339,"Expires":0},{"Key":"2YQJ5JMXVOJ4RJZPVEJH6R6SIX66FCO4ILQZZMKRPAI4XUXUTORA","Offset":1072815936,"Log":2339,"Length":124160,"Created":20339,"Expires":0},{"Key":"YLH43VISOJAZA5HMPSEGIH4WQIPMR2HUAZEV4QLVBQWLD5E264NQ","Offset":1072559552,"Log":2339,"Length":182016,"Created":20339,"Expires":0}], "log": [{"Key":"P25MRPQITOWJPJEZWXAJFOP6C22TIP6JYY72HDLLRTLERBUA5AKA","Offset":1073485568,"Log":2339,"Length":648704,"Created":20339,"Expires":0},{"Key":"5QAGPEAF2LWY3AHAIR6HVBLDK2VE4JHAFJ44QELW2KXXE3YWXVWQ","Offset":1073303488,"Log":2339,"Length":182016,"Created":20339,"Expires":0},{"Key":"27Y3HXCP5R2JGJANPS2AZ35ZJPSVILFHHQBHRFXJKLFBWQJRGYYA","Offset":1072940160,"Log":2339,"Length":363264,"Created":20339,"Expires":0},{"Key":"2YQJ5JMXVOJ4RJZPVEJH6R6SIX66FCO4ILQZZMKRPAI4XUXUTORA","Offset":1072815936,"Log":2339,"Length":124160,"Created":20339,"Expires":0},{"Key":"FGCZMFC2PCE52IEX6M5BNI6FBAEPZQ5PSQGVU6ZPZVN5EKL3JITQ","Offset":1072741632,"Log":2339,"Length":74240,"Created":20339,"Expires":0}]}
2026-03-21T15:14:32Z    WARN    hashstore       mismatched log tail     {"process": "storagenode", "satellite": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "store": "s0", "id": 4389, "path": "config/storage/hashstore/12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S/s0/25/log-0000000000001125-00000000", "table": [{"Key":"6NDLBWCRXTJNED6P4QJBWICCTGHFHGOSNBBFXYECOU3WSJVU3DQQ","Offset":1073091008,"Log":4389,"Length":725504,"Created":20404,"Expires":0},{"Key":"6NYN5TD5WYES7GYW575UMLR2Z5HVFCBT6IYXPWV5RQ5VRFWMQUHQ","Offset":1073066048,"Log":4389,"Length":14848,"Created":20404,"Expires":0},{"Key":"6NXVG3GFDEOQGF44QI7W6NVY47KQMRO6EBOSXCEZ2N4D4IHFXPNA","Offset":1072340480,"Log":4389,"Length":725504,"Created":20404,"Expires":0},{"Key":"6N3LXRPIJ6QGCUXZVSJYLBJ3XVQOEDPGAUDDAQTKQ5NWUNMUH5PA","Offset":1072326848,"Log":4389,"Length":13568,"Created":20404,"Expires":0},{"Key":"6NNAFGQIMNTLDEA4WE54MRADZAAPCE2EOC6GW65LRZNSNL5O6NJA","Offset":1072320640,"Log":4389,"Length":6144,"Created":20404,"Expires":0}], "log": [{"Key":"6NDLBWCRXTJNED6P4QJBWICCTGHFHGOSNBBFXYECOU3WSJVU3DQQ","Offset":1073091008,"Log":4389,"Length":725504,"Created":20404,"Expires":0},{"Key":"6NPYUJ63X7R7TPXHZ2OGGLLNA2LBOYLKXZLNBGOHCSPYSHG5FKUA","Offset":1073080960,"Log":4389,"Length":9984,"Created":20404,"Expires":0},{"Key":"6NYN5TD5WYES7GYW575UMLR2Z5HVFCBT6IYXPWV5RQ5VRFWMQUHQ","Offset":1073066048,"Log":4389,"Length":14848,"Created":20404,"Expires":0},{"Key":"6NXVG3GFDEOQGF44QI7W6NVY47KQMRO6EBOSXCEZ2N4D4IHFXPNA","Offset":1072340480,"Log":4389,"Length":725504,"Created":20404,"Expires":0},{"Key":"6N3LXRPIJ6QGCUXZVSJYLBJ3XVQOEDPGAUDDAQTKQ5NWUNMUH5PA","Offset":1072326848,"Log":4389,"Length":13568,"Created":20404,"Expires":0}]}
2026-03-21T15:15:09Z    WARN    hashstore       mismatched log tail     {"process": "storagenode", "satellite": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "store": "s0", "id": 6694, "path": "config/storage/hashstore/12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S/s0/26/log-0000000000001a26-00000000", "table": [{"Key":"752LJVNLHLE46RAYNN36M4RY325ZCNXSJDY3NNPMT7P65RFJH7DQ","Offset":1073372736,"Log":6694,"Length":2319872,"Created":20490,"Expires":0},{"Key":"ICFU4RSYQJZBL3MFXZROA3IYQXXBIT7DWWB2AMIFUTIPLRB6P7BQ","Offset":1073190656,"Log":6694,"Length":182016,"Created":20490,"Expires":0},{"Key":"4F7EZ3XT3AGU3ESHCNWVKJRHPLXIBAGFGSDSXQ5D5LXM3JY35Y4A","Offset":1073008576,"Log":6694,"Length":182016,"Created":20490,"Expires":0},{"Key":"Y2MCUK46B5M2T242EB46FX4SAUALTXO7KKGK43H2XEDNL5EXA7FQ","Offset":1072876160,"Log":6694,"Length":132352,"Created":20490,"Expires":0},{"Key":"ZXL2MZ4D2N4MFW57XF54MQTQLQ5T6RTQGOGN3EMMA2XNGIQ76JFQ","Offset":1070513152,"Log":6694,"Length":2319872,"Created":20490,"Expires":0}], "log": [{"Key":"752LJVNLHLE46RAYNN36M4RY325ZCNXSJDY3NNPMT7P65RFJH7DQ","Offset":1073372736,"Log":6694,"Length":2319872,"Created":20490,"Expires":0},{"Key":"ICFU4RSYQJZBL3MFXZROA3IYQXXBIT7DWWB2AMIFUTIPLRB6P7BQ","Offset":1073190656,"Log":6694,"Length":182016,"Created":20490,"Expires":0},{"Key":"4F7EZ3XT3AGU3ESHCNWVKJRHPLXIBAGFGSDSXQ5D5LXM3JY35Y4A","Offset":1073008576,"Log":6694,"Length":182016,"Created":20490,"Expires":0},{"Key":"Y2MCUK46B5M2T242EB46FX4SAUALTXO7KKGK43H2XEDNL5EXA7FQ","Offset":1072876160,"Log":6694,"Length":132352,"Created":20490,"Expires":0},{"Key":"FJ6GOYCRG3FDB4BGPVVESG6Z5SGIZ3UZQZEEAW353GLEQBTVSCCQ","Offset":1072833088,"Log":6694,"Length":43008,"Created":20490,"Expires":0}]}
2026-03-21T15:15:27Z    WARN    hashstore       mismatched log tail     {"process": "storagenode", "satellite": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "store": "s0", "id": 3114, "path": "config/storage/hashstore/12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S/s0/2a/log-0000000000000c2a-00000000", "table": [{"Key":"TAYF55EN5GEO7X3M45CZM7K7YOK6OJBUQAEG7R4GZ2IZ7Q2TFEGQ","Offset":1073200064,"Log":3114,"Length":2319872,"Created":20400,"Expires":0},{"Key":"TA3GAAORL26BVNWD4ZEQXSI4PDULNSCEFBD4E4GHKAFZY4U5CXUA","Offset":1073193344,"Log":3114,"Length":6656,"Created":20400,"Expires":0},{"Key":"TAGA3OWSIT257D6QAXEAIA6FGRJ3JW3NONC3ZAHBAXUD7NJHA3HQ","Offset":1073152512,"Log":3114,"Length":4352,"Created":20400,"Expires":0},{"Key":"TAUZM2OJW5JXQXYHAK3535HA6YAFZS5I34T3IZLD66C6HY342ULQ","Offset":1073148352,"Log":3114,"Length":4096,"Created":20400,"Expires":0},{"Key":"TAWMHLUXHXGBD66MJPH646PK3VWZMBYSDLJVPC3JNTRYZICDM6BA","Offset":1073134208,"Log":3114,"Length":14080,"Created":20400,"Expires":0}], "log": [{"Key":"TAYF55EN5GEO7X3M45CZM7K7YOK6OJBUQAEG7R4GZ2IZ7Q2TFEGQ","Offset":1073200064,"Log":3114,"Length":2319872,"Created":20400,"Expires":0},{"Key":"TA3GAAORL26BVNWD4ZEQXSI4PDULNSCEFBD4E4GHKAFZY4U5CXUA","Offset":1073193344,"Log":3114,"Length":6656,"Created":20400,"Expires":0},{"Key":"TARRVCCQSOHIJR434WN53Q6M5DV7F3LYSQSVPEO5YI4KNJNB5PPA","Offset":1073156928,"Log":3114,"Length":36352,"Created":20400,"Expires":0},{"Key":"TAGA3OWSIT257D6QAXEAIA6FGRJ3JW3NONC3ZAHBAXUD7NJHA3HQ","Offset":1073152512,"Log":3114,"Length":4352,"Created":20400,"Expires":0},{"Key":"TAUZM2OJW5JXQXYHAK3535HA6YAFZS5I34T3IZLD66C6HY342ULQ","Offset":1073148352,"Log":3114,"Length":4096,"Created":20400,"Expires":0}]}
2026-03-21T15:16:03Z    WARN    hashstore       mismatched log tail     {"process": "storagenode", "satellite": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "store": "s0", "id": 3627, "path": "config/storage/hashstore/12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S/s0/2b/log-0000000000000e2b-00000000", "table": [{"Key":"TSPU2NX4MJNLH3W4EOTCIPNQZDULQCX47SNND5EJWXHPMKJZHJHQ","Offset":1072910528,"Log":3627,"Length":1305344,"Created":20400,"Expires":0},{"Key":"TSMP2GMVNYW7YXU7QFAYIDDRNRAGZJOJV5WQIEPO2M4LK4IGCTLA","Offset":1072728448,"Log":3627,"Length":182016,"Created":20400,"Expires":0},{"Key":"TSAOH5VC4DQUSLJEKC2UWSHR5LMX7NR6AFOXCQIE476UUTV7TU4A","Offset":1072653376,"Log":3627,"Length":75008,"Created":20400,"Expires":0},{"Key":"TSH3WWJ7MWYVL6NT7HVBDGWTGSTCQVVLCUPJP7Q7LDZ52XMJH3RA","Offset":1072648192,"Log":3627,"Length":5120,"Created":20400,"Expires":0},{"Key":"TSIK7NS3MQLZ7YBXZ2CTCYV64POMN7GVZVUKQAXGUCOETSNDIYTA","Offset":1072607872,"Log":3627,"Length":34816,"Created":20400,"Expires":0}], "log": [{"Key":"TSPU2NX4MJNLH3W4EOTCIPNQZDULQCX47SNND5EJWXHPMKJZHJHQ","Offset":1072910528,"Log":3627,"Length":1305344,"Created":20400,"Expires":0},{"Key":"TSMP2GMVNYW7YXU7QFAYIDDRNRAGZJOJV5WQIEPO2M4LK4IGCTLA","Offset":1072728448,"Log":3627,"Length":182016,"Created":20400,"Expires":0},{"Key":"TSAOH5VC4DQUSLJEKC2UWSHR5LMX7NR6AFOXCQIE476UUTV7TU4A","Offset":1072653376,"Log":3627,"Length":75008,"Created":20400,"Expires":0},{"Key":"TSH3WWJ7MWYVL6NT7HVBDGWTGSTCQVVLCUPJP7Q7LDZ52XMJH3RA","Offset":1072648192,"Log":3627,"Length":5120,"Created":20400,"Expires":0},{"Key":"TSKDH6LNPO2LSLLM75IO2FRJHOWYWMFJ2BG4XBDHNBUAZQ4NFU2Q","Offset":1072642752,"Log":3627,"Length":5376,"Created":20400,"Expires":0}]}
Just letting the node run and wait till the warnings are over?
They should be fixed by hashstore fsck:
