Noeud lancé mais rien
Ca fait la même chose. On regarde demain car la, j’en ai raz le bol ;(
bonne soiree et merci
Me revoilà…
J’ai réinstallé mon serveur je n’ai pas fais de règles iptables ou quoi que ce soit. J’ai refais une identité
et toujours le même soucis. Je ne comprends rien du tout.
le log :
2021-02-09T17:47:33.259Z INFO trust Scheduling next refresh {“after”: “7h54m30.113392509s”}
2021-02-09T17:47:33.261Z ERROR gracefulexit:chore error retrieving satellites. {“error”: “satellitesdb error: context canceled”, “errorVerbose”: “satellitesdb error: context canceled\n\tstorj.io/storj/storagenode/storagenodedb.(*satellitesDB).ListGracefulExits:100\n\tstorj.io/storj/storagenode/gracefulexit.(*service).ListPendingExits:89\n\tstorj.io/storj/storagenode/gracefulexit.(*Chore).Run.func1:53\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/storj/storagenode/gracefulexit.(*Chore).Run:50\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:81\n\truntime/pprof.Do:40\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:80\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2021-02-09T17:47:33.262Z ERROR gracefulexit:blobscleaner couldn’t receive satellite’s GE status {“error”: “context canceled”}
2021-02-09T17:47:33.263Z ERROR piecestore:cache error during init space usage db: {“error”: “piece space used error: context canceled”, “errorVerbose”: “piece space used error: context canceled\n\tstorj.io/storj/storagenode/storagenodedb.(*pieceSpaceUsedDB).Init:73\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:75\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:81\n\truntime/pprof.Do:40\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:80\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
acidburn@ns307488:~$
root@ns307488:/home/acidburn# docker exec -it storagenode /app/dashboard.sh
2021-02-09T18:21:15.473Z INFO Configuration loaded {“Location”: “/app/config/config.yaml”}
2021-02-09T18:21:15.567Z INFO Identity loaded. {“Node ID”: “12kfUFPNPGSotiPbLqDsnbcUoqZBZLCxAaAExxxxxxxxxxxxxxxxxxx1”}
Error: context canceled
  • Quelle est la commande docker que vous utilisez après cette réinstallation complète ?
  • Comment le disque de stockage est-il connecté ?
  • Cet espace de stockage est-il inscriptible par le processus docker ?
Cela suggère que vous essayez d’exécuter le nœud, qui est déjà sorti de certains satellites.
Êtes-vous sûr que c’est une nouvelle identité?
Si vous voulez partir de zéro, vous devez tout supprimer, inclure toutes les données et l’ancienne identité, puis en générer une nouvelle et la signer avec un nouveau jeton d’autorisation, puis commencer le mode de stockage avec cela identité et stockage propre.
Le problème de connexion généralement lié à l’adresse externe, il doit être présent dans l’option ADDRESS (dans le cas de Docker) ou dans le config.yaml. Il doit être spécifié sous la forme my.external.address:28967.
L’autre problème pourrait être si votre IP WAN sur votre routeur ne correspond pas à l’IP sur votre site de signal.
Ce qu’Alexey entend par là, c’est “Si vous voulez repartir de zéro, vous devez tout supprimer, y compris toutes les données et l’ancienne identité”.
[@Alexey Just clarifying what the auto-translator failed to translate in a clear way].
@AcidBurn18 : Est-ce possible pour vous de converser en Anglais ? Cela permettrait à beaucoup plus de membres du forum d’être en mesure de vous porter assistance.
[Asking them if it’s possible to switch to English for a better chance to get help from other members]
Good news … I finally managed to launch everything without worries. I just put my Iptables rules and there, it’s the drama.
3a0481c3ce4194d591820870c7b3c0695acb6a4712c62f1688c601de62b9c818
docker: Error response from daemon: driver failed programming external connectivity on endpoint storagenode (a8a469154be7d82afaecd329c288966dc6340362a807d2cd97b885c0cdbc4c57): (iptables failed: iptables --wait -t filter -A DOCKER ! -i docker0 -o docker0 -p tcp -d 172.17.0.2 --dport 28967 -j ACCEPT: iptables: No chain/target/match by that name.
(exit status 1)).
my iptables rules:
Storj Dashboard
iptables -t filter -A INPUT -p tcp --dport 14002:14002 -j ACCEPT
iptables -t filter -A OUTPUT -p tcp --dport 14002:14002 -j ACCEPT
#Storj Mining
iptables -t filter -A INPUT -p tcp --dport 28967:28967 -j ACCEPT
iptables -t filter -A OUTPUT -p tcp --dport 28967:28967 -j ACCEPT
So everything is good. Once the rules have been launched, you have to reinstall Docker.
  • sudo apt-get purge docker docker-engine docker.io containerd runc docker-ce docker-ce-cli containerd.io
  • sudo apt-get update
  • sudo apt-get install docker-ce docker-ce-cli containerd.io
Everything works as it should.
Thank you all for your help and please be patient with me.
Glad you got it working :+1:
bonjour @AcidBurn18 ,
je viens de voir ce topic, je suis nouvel utilisateur depuis qqs jours.
Je vois que tu utilises une version de storj 1.24. peut être dois-tu le mettre à jour ?
cdlt
je vais essyer sur un RPI3 et 1 hdd 1To pour essayer un nouveau noeud :slight_smile:
Bonjour @philippe456 et bienvenue sur le forum !
Pour une meilleure visibilité et être compris par tous, je vous conseille de vous exprimer en anglais si cela vous est possible ^^
[Welcoming them and suggesting to use english]
C’était il y a 1 an, je pense qu’il doit être à jour maintenant :wink:
