I was following the video provided by Will Topping (thank you for that, just needs a slight update), but am getting tripped up at the unzipping of the Raspberry Pi portion where I need to run this command:
unzip ~/identity_linux_arm.zip
After I hit enter, I get this:
Archive: /root/identity_linux_arm.zip
End-of-central-directory signature not found. Either this file is not
a zipfile, or it constitutes one disk of a multi-part archive. In the
latter case the central directory and zipfile comment will be found on
the last disk(s) of this archive.
unzip: cannot find zipfile directory in one of /root/identity_linux_arm.zip or
/root/identity_linux_arm.zip.zip, and cannot find /root/identity_linux_arm.zip.ZIP, period.
Any help you can provide is greatly appreciated.
