Offline after power outage nodes on Docker
Hi, I’m having trouble to get my nodes online after power outage last night. I have two 4TB nodes v.1.1.1.
Running Docker. One on Ubuntu and one on Mac.
The logs is saying:
2020-04-30T17:45:39.097Z INFO version running on version v1.1.1
2020-04-30T17:45:39.694Z INFO db.migration Database Version {“version”: 33}
2020-04-30T17:45:40.735Z INFO preflight:localtime start checking local system clock with trusted satellites’ system clock.
2020-04-30T17:45:41.657Z INFO preflight:localtime local system clock is in sync with trusted satellites’ system clock.
2020-04-30T17:45:41.657Z INFO bandwidth Performing bandwidth usage rollups
2020-04-30T17:45:41.658Z INFO Node 1wwBNvrTC9wqvppkHwnLPHoF3mtoYuEtbpRn8cyQddHfHAo82H started
2020-04-30T17:45:41.658Z INFO Public server started on [::]:28967
2020-04-30T17:45:41.658Z INFO Private server started on 127.0.0.1:7778
2020-04-30T17:45:41.659Z INFO trust Scheduling next refresh {“after”: “3h2m12.523929701s”}
2020-04-30T17:45:41.661Z WARN piecestore:monitor Used more space than allocated. Allocating space {“bytes”: 3500000000000}
Are you using a ddns? Check your IP address to make sure the port is still open.
Yes, I’m using noip.com (hopto.org addr.). My ddns name matching my ip and ports are open.
I think you was perfectly right. My No-IP DUC was not running on my Mac. I started it after i read your message, so i think it updated my IP before i checked. Should have remembered to check it myself!
Killed my nodes and started again. All OK :smiley:
Thank you, @deathlessdd !
Do you have the ability to set it on your router that would be a much better way, incase it happens again.
Thank you, again!
I have now registered Dynamic DNS on my router (Zyxel 8702) :smiley:
Don’t forget to remove the DUC from all your PC/Mac, otherwise they will contradict each other
