(i knew how to use notepad++ just not this service)thanks for the heads up tho. i am however officially stuck.
i restarted the router. the only thing i have not done is dns flush and factory reset. i also have the rules on the firewall open on that port both ways. inbound has edge traversal and it’s blocked. your tutorials don’t mention that so i left it as is.Please, do the one thing:
- Go to the main page of your router and write down the WAN IP
- Go to the Open Port Check Tool - Test Port Forwarding on Your Router and compare with WAN IP.
If they match - then something blocking the traffic because port is closed.
If they do not match - the port forwarding will not work, because your router behind another NAT. You need to make a rule on that another NAT (likely it is on ISP’s side).
Please, remove the outbound rule from your firewall. Or make it to allow to access to any port, not only 28967.
The inbound rule should allow 28967 only
If storagenode is disqualified on all satellites, it could never be online anymore. You need to create a new identity and sign it with a new authorization token.
