I hit the subject message while attempting to restart my node. After reading the instructions found here, I attempted to restart the node and now I get the following:
2022-07-20T03:03:06.226352144Z 2022-07-20 03:03:06,225 INFO success: processes-exit-eventlistener entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2022-07-20T03:03:06.237853573Z 2022-07-20 03:03:06,235 INFO spawned: 'storagenode' with pid 47
2022-07-20T03:03:06.239348832Z 2022-07-20 03:03:06,238 INFO success: storagenode-updater entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2022-07-20T03:03:06.520026244Z 2022-07-20T03:03:06.518Z INFO Configuration loaded {"Process": "storagenode", "Location": "/app/config/config.yaml"}
2022-07-20T03:03:06.524856615Z 2022-07-20T03:03:06.522Z INFO Operator email {"Process": "storagenode", "Address": "galewis@yaddatech.com"}
2022-07-20T03:03:06.526995854Z 2022-07-20T03:03:06.523Z INFO Operator wallet {"Process": "storagenode", "Address": "0x5a6F11Ab07A974463Ad0A839B004b40588e9B5Ec"}
2022-07-20T03:03:06.947141297Z 2022-07-20T03:03:06.945Z INFO Telemetry enabled {"Process": "storagenode", "instance ID": "1SdoZv6L8E32agbFGRbrJt97TYwLek8kLBzuWNLMx1nAqKHYiW"}
2022-07-20T03:03:07.095021778Z 2022-07-20T03:03:07.093Z INFO db.migration Database Version {"Process": "storagenode", "version": 53}
2022-07-20T03:03:08.098332614Z 2022-07-20 03:03:08,097 INFO success: storagenode entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2022-07-20T03:03:08.220368641Z Error: Error during preflight check for storagenode databases: preflight: database "pieceinfo": expected schema does not match actual: &dbschema.Schema{
2022-07-20T03:03:08.220856824Z - Tables: []*dbschema.Table{
2022-07-20T03:03:08.220915243Z - (
2022-07-20T03:03:08.220941369Z - s"""
2022-07-20T03:03:08.220967328Z - Name: pieceinfo_
2022-07-20T03:03:08.220992704Z - Columns:
2022-07-20T03:03:08.221017538Z - Name: deletion_failed_at
2022-07-20T03:03:08.221042664Z - Type: TIMESTAMP
2022-07-20T03:03:08.221067956Z - Nullable: true
2022-07-20T03:03:08.221092916Z - Default: ""
2022-07-20T03:03:08.221118375Z - Reference: nil
2022-07-20T03:03:08.221143542Z - Name: order_limit
2022-07-20T03:03:08.221168626Z - Type: BLOB
2022-07-20T03:03:08.221193669Z - Nullable: false
2022-07-20T03:03:08.221218586Z - Default: ""
2022-07-20T03:03:08.221244129Z - Reference: nil
2022-07-20T03:03:08.221269005Z - Name: piece_creation
2022-07-20T03:03:08.221293922Z - Type: TIMESTAMP
2022-07-20T03:03:08.221318673Z - Nullable: false
2022-07-20T03:03:08.221343674Z - ... // 37 elided lines
2022-07-20T03:03:08.221368258Z - s"""
2022-07-20T03:03:08.221392967Z - ),
2022-07-20T03:03:08.221417135Z - },
2022-07-20T03:03:08.221441386Z + Tables: nil,
2022-07-20T03:03:08.221465595Z - Indexes: []*dbschema.Index{
2022-07-20T03:03:08.221490262Z - s`Index<Table: pieceinfo_, Name: idx_pieceinfo__expiration, Columns: piece_expiration, Unique: false, Partial: "piece_expiration I`...,
2022-07-20T03:03:08.221650393Z - s`Index<Table: pieceinfo_, Name: pk_pieceinfo_, Columns: satellite_id piece_id, Unique: true, Partial: "">`,
2022-07-20T03:03:08.221679144Z - },
2022-07-20T03:03:08.221703644Z + Indexes: nil,
2022-07-20T03:03:08.221728312Z Sequences: nil,
2022-07-20T03:03:08.221753063Z }
2022-07-20T03:03:08.221776939Z
2022-07-20T03:03:08.221800481Z storj.io/storj/storagenode/storagenodedb.(*DB).preflight:406
2022-07-20T03:03:08.221825065Z storj.io/storj/storagenode/storagenodedb.(*DB).Preflight:353
2022-07-20T03:03:08.221850024Z main.cmdRun:241
2022-07-20T03:03:08.221877650Z storj.io/private/process.cleanup.func1.4:372
2022-07-20T03:03:08.221902734Z storj.io/private/process.cleanup.func1:390
2022-07-20T03:03:08.221927235Z github.com/spf13/cobra.(*Command).execute:852
2022-07-20T03:03:08.221951611Z github.com/spf13/cobra.(*Command).ExecuteC:960
2022-07-20T03:03:08.221976029Z github.com/spf13/cobra.(*Command).Execute:897
2022-07-20T03:03:08.222000613Z storj.io/private/process.ExecWithCustomConfigAndLogger:93
2022-07-20T03:03:08.222025239Z main.main:479
2022-07-20T03:03:08.222049239Z runtime.main:255
2022-07-20T03:03:08.234150022Z 2022-07-20 03:03:08,233 INFO exited: storagenode (exit status 1; not expected)
2022-07-20T03:03:09.248765072Z 2022-07-20 03:03:09,246 INFO spawned: 'storagenode' with pid 56
2022-07-20T03:03:09.250357209Z 2022-07-20 03:03:09,249 WARN received SIGQUIT indicating exit request
2022-07-20T03:03:09.253381894Z 2022-07-20 03:03:09,251 INFO waiting for storagenode, processes-exit-eventlistener, storagenode-updater to die
2022-07-20T03:03:09.254971781Z 2022-07-20T03:03:09.252Z INFO Got a signal from the OS: "terminated" {"Process": "storagenode-updater"}
2022-07-20T03:03:09.266795304Z 2022-07-20 03:03:09,265 INFO stopped: storagenode-updater (exit status 0)
2022-07-20T03:03:09.274084300Z 2022-07-20 03:03:09,273 INFO stopped: storagenode (terminated by SIGTERM)
2022-07-20T03:03:09.277699588Z 2022-07-20 03:03:09,276 INFO stopped: processes-exit-eventlistener (terminated by SIGTERM)
Not sure what this means or how to fix it.
