Hello,
I have a node that is logging a lot of “piecemigrate:chore couldn’t migrate”.
hashstore configuration
root@mcanto:/NODE/NODE1/storage/hashstore/meta# cat *.migrate
{“PassiveMigrate”:true,“WriteToNew”:true,“ReadNewFirst”:true,“TTLToNew”:true}
remaining data in blobs
root@mcanto:/NODE/NODE1/storage/blobs# sudo du -hs *
32K qstuylguhrn2ozjv4h2c6xpxykd622gtgurhql2k7k75wqaaaaaa
1,4G ukfu6bhbboxilvt7jrwlqk7y2tapb5d2r2tsmj2sjxvw5qaaaaaa
40G v4weeab67sbgvnbwd5z7tweqsqqun7qox2agpbxy44mqqaaaaaaa
root@mcanto:/NODE/NODE1/storage/blobs# find /NODE/NODE1/storage/blobs -type f | wc -l
84940
root@mcanto:/NODE/NODE1/storage/blobs# grep “couldn’t migrate” /STORJ_LOCAL/LOG/node.log | wc -l
84930
since we are talking about 41GB of data over 8.85TB , can I delete them ?
or how can I stop the migration ? My logs yesterday go to 7 GB and filesystem got full.
Every 5minutes (more or less) it try to migrate and add 84930 lines in the LOGS
this is my docker environment
- STORAGE=11700GB
- STORJ_PIECES_ENABLE_LAZY_FILEWALKER=true
- STORJ_STORAGE2_PIECE_SCAN_ON_STARTUP=false
- STORJ_LOG_LEVEL=info
#- STORJ_LOG_CUSTOM_LEVEL=blobscache=FATAL,piecestore=WARN,piecemigrate=WARN
- STORJ_GARBAGE_COLLECTION_CONCURRENCY=1
- STORJ_STORAGE2_DATABASE_CACHE_SIZE=32768
- STORJ_STORAGE2_HASHSTORE_WRITE_TO_NEW=true
- STORJ_STORAGE2_HASHSTORE_TTL_TO_NEW=true
- STORJ_STORAGE2_HASHSTORE_PASSIVE_MIGRATE=false
- STORJ_STORAGE2_PIECE_MIGRATE_CHORE=false
Best regards
