How can I check to see if my port forwarding is working or not?
If your port is OFFLINE, you can try a service such as https://www.yougetsignal.com/tools/open-ports/
The IP and port should match what you set. -
What are some other issues to check for?
– Make sure your firewall isnt blocking your port.
– Make sure your IP is static or that your have a properly working DDNS
– Check to make sure NAT - Port Triggering on your router is configured correctly
Also make sure your router has a public IP address. That usually requires you to put your ISP provided modem into bridge mode and passing the public IP to your router. I know AT&T with either fiber or DSL requires this.
Also, be sure to add the port into the windows firewall.
Click windows button
Type: Windows Defender Firewall (do not select “Windows Defender settings”)
Select “Advanced setting” on the left-hand menu
Select “Inbound rules”
Select “New Rule…”
-What type of rule would you like to create?-
Select “Port”
Click Next
Select “TCP”
Select Specific local ports: [Enter the port assigned from Storj]
Select “Allow the connection”
Click next
Make sure all boxes are checked
Click next
Name: [Storj Name you desire]
Click finish
Run a port checker to see if it’s open.
https://portchecker.co/
