I’m curious about the power usage implications of using Hashstore versus Piecestore in Storj. Does anyone know if there’s a significant difference in energy consumption between these two models? Hashstore seems to focus on metadata and hashes, which could mean less strain on disks. What are your thoughts?
It might be the same - but when having many nodes - alot of power is being used. So here even 10% reduction would be awesome
Fully agree, it’s a pure theoretical discussion. Like dropping a needle in the ocean raises water levels, but not really.
There are three major energy consumers in HDD
motor, overcoming friction, all the time
Actuators moving heads
Electronics running firmware.
You can’t do anything about the first, but you sure can, and drives do, everything about the second and last. Search for “Extended Power Conditions”. On FreeBSD you can use camcontrol to check what power modes your HDD suppoprts
camcontrol epc da0 -c status
In the frame of this discussion – fewer actuator jerks, fewer energy wasted, and in parallel, more opportunity for firmware to sleep.
Writing logs requires fewer IO than writing individual files, so here where the differnce will come from. Granted, ZFS already does it with piecestore as well, so no difference there.
No, because it happens infrequently and all at once, and then back to idle, allowing CPUs and HDDs firmware to sleep. Short bursts of compactions is therefore irrelevant, what matters is what happens all the time.
Which brings us to the deletion. There are no piece deletions with hashstore, at all, and with piece store deleting takes CPU time and memory pressure, all of which are quite power hungry. This is another source of pin in the ocean power savings.
If you dont know - you are currently on piecestore
but in some time we will all go to the new hashstore - as far as i know - you dont need to do anything.
Thank you. Do you know with which version is the automatic migration coming?
Some of my nodes are on v1.135.5, and some on v1.136.4.
After migration, do I need to delete any temporary directories? Guide on one of the links you provided mentions deleting files from blobs directory.
