Yes, update your docker run command: https://documentation.storj.io/setup/cli/storage-node#running-the-storage-node
Also, do not use a network connected drives for the storage.
Ahh, we changed back from -v to --mount? I will change that!
Also, concerning the Notice:
Linux Users: You must static mount via /etc/fstab. Failure to do so will put you in high risk of failing audits and getting disqualified. Here’s how to do that.
As I have had very bad experiences in changing things in the fstab, I’d rather not do that directly. I made a mount on startup through the Centos7 disks utility (linked with the UUID of the device) as I thought this would make an fstab entry for me. Is that solution acceptable or is this exactly what is not advised?
Please, give me result of the command
df -h
Almost a year ago. We have not had the --mount before
Ahh, I see. The --stop-timeout 300 flag is now used in the run command. I will add that asap.
Also:
$ df -h
results in:
/dev/sdb1 4.6T 281G 4.1T 7% /media/user/storj_drive
Thanks for the great support, Alexey!
grep "/media/user" /etc/fstab
$ grep "/media/user" /etc/fstab
/dev/disk/by-uuid/6fea7213-3728-434b-aba3-3704dcd94942 /media/user/storj_drive auto nosuid,nodev,nofail,x-gvfs-show 0 0
It looks like properly mounted
