I am following the Tardigrade rclone tutorial
https://documentation.tardigrade.io/how-tos/sync-files-with-rclone
and after having set the configuration I run into an error…
[folaht@pjehrsohmehj Prive]$ rclone lsf tardigrade:mybucket
Enter configuration password:
password:
2021/03/03 17:25:26 Failed to create file system for "tardigrade:mybucket": didn't find section in config file
I’m not sure if this is a tardigrade issue or an rclone issue.
[update]
When setting the project name to the remote name, I get this error instead:
[folaht@pjehrsohmehj Tardigrade]$ rclone mkdir tardigrade:mybucket
password:
2021/03/04 12:08:25 Failed to create file system for "tardigrade:mybucket": access not found
[update]
I managed to have a different error by matching my default access grant name.
[folaht@pjehrsohmehj Tardigrada]$ rclone mkdir tardigrade:mybucket
password:
2021/03/04 15:56:09 Failed to create file system for "tardigrade:mybucket": tardigrade: access: uplink: invalid access grant format
[update]
For whatever reason, rclone skips api_key and passphrase, unless when remote is edited.
When added api_key and passphrase:
[nwazj]
type = tardigrade
satellite_address = europe-west-1.tardigrade.io
api_key = ...
passphrase = ...
provider = existing
Still this leaves with this issue:
password:
2021/03/04 16:19:32 Failed to create file system for "tardigrade:mybucket": tardigrade: access: uplink: metainfo error: node ID is required in node URL "europe-west-1.tardigrade.io"
