well thats the method storj recommends… so should be fine…
also really the best performance to the amount of hardware used solution, you might want to run something like zfs so you can keep an eye on how the data integrity is, disk health monitoring will only tell you so much…
zfs will keep checksums on everything and thus you will be informed upon errors popping up for whatever reasons… like bad cables and what not…
There are no safe choices, the manufacturers may change mind any time. However, so far there were no reported SMR drives within WD Elements/Easystores/MyBooks ≥ 8TB and Seagate Expansions ≥ 10 TB.
I guess I’ve finally found the reason of my heavy load in this thread, and at the same time that I don’t have the disk I thought I had.
Brief story : I started a node about a year ago with one of the disks listed at the top of this thread. It went relatively well, with sometimes an alert on the load but nothing too worrying. Until a few weeks ago when the disk usage reached ~ 65 %. The load alerts became more often until the disk had a sudden stop and I started to investigate. The load was then skyrocketing. And I found this thread.
After reading it, I learnt about the storage2.max-concurrent-requests setting. Is it the only thing that can be acted on to try to mitigate the heavy writings ?
Yeah, it sucks that they are not upfront about it. At least these days you can find the info when you know to look for it.
There isn’t much you can do other than that setting. Other options require other HDD’s. Make sure you use the noatime mounting option if you use Linux though.
Other things you can do is move DB’s to another drive (preferably SSD, but not required). Another option is to run a second node on another HDD which will spread the write load.
Thanks for the hints. The noatime has already decreased around 25% of the peak load. For the DB files, I guess they are all the *.db, *.db-wal and *.db-shm from the storage directory ?
