My raspberry pi 3 that I’m running my SNO on suddenly stopped booting correctly (red light on, green light off). I tried a bunch of things recommended on the internet, but nothing has worked so far. This is what I tried:
- mounted the sd card on my mac and added init=/bin/sh to the end of cmdline.txt
- remounted sd card on the pi, with external monitor.
- pi now reads:
/bin/sh: 0: can't access tty: job control turned off... couldn't find an input interrupt endpoint
- attempted to follow these instructions [Solved] Emergency Mode Due to Bad fstab – Jeff Clark's Blog but no luck (got error with can’t find PARTUUID)
- Attempted Can't find PARTUUID=eb55478c-02 - Raspberry Pi Forums but couldn’t write to /etc/fstab even with chmod
Has anyone run into an issue like this before, or have any other ideas what I could try? Thanks so much!
