So my node was disqualified (due to my own fault). I tried getting new token, got it, but node still doesn’t run. What should I do? Or is it permanent disqualification per IP?
You need to delete old identity and data if you want to start from scratch. Your identity is tied to your data so you can’t use new identity for old data.
No
Also make sure you don’t repeat said mistake for your new node.
I DID delete the old one. Restarted everything from docker to Linux. Nothing helps…
Just make sure you deleted the whole folder with blobs
and database files in them. What does your log show ?
I completely formatted HDD, unmounted, mounted again. I’ll check tomorrow and reply here.
So it starts and runs now, just earnings.py shows DQ for all sattelites. I know it’s 3rd party tool but still… Should I wait? Is there any other way to check if node is correctly operational? I have no way to use GUI dashboard, installed node runs on Linux without GUI.
Check web dashboard by visiting 127.0.0.1:14002
in Chrome or firefox
I can’t as I mentioned, I have no possibility to use GUI. Linux is only with CLI.
You can open web dashboard remotely
https://documentation.storj.io/resources/faq/how-to-remote-access-the-web-dashboard#install-a-ssh-client-on-your-device
Show me result your docker run command and remove any personal info from it.
Just restarted the node:
[root@localhost ~]# docker logs storagenode 2>&1 | grep -v Operator
2020-05-06T12:25:32.869Z INFO Configuration loaded {"Location": "/app/config/config.yaml"}
2020-05-06T12:25:32.918Z INFO tracing disabled
2020-05-06T12:25:38.301Z INFO db.migration Database Version {"version": 36}
2020-05-06T12:25:39.063Z INFO preflight:localtime start checking local system clock with trusted satellites' system clock.
2020-05-06T12:25:40.125Z INFO preflight:localtime local system clock is in sync with trusted satellites' system clock.
2020-05-06T12:25:40.128Z INFO bandwidth Performing bandwidth usage rollups
2020-05-06T12:25:40.139Z INFO Node 15hQPfQjpvjXhWVuEcJBmcAEtA6df3SsgW1Uba15AFyWZxf6EL started
2020-05-06T12:25:40.139Z INFO Public server started on [::]:28967
2020-05-06T12:25:40.139Z INFO Private server started on 127.0.0.1:7778
2020-05-06T12:25:40.166Z INFO trust Scheduling next refresh {"after": "9h1m4.39887855s"}
2020-05-06T12:25:44.879Z INFO piecestore upload started {"Piece ID": "MM5SGBQ6S5W34FSKZZZKT4W3EBUQ5ALACY2DA4IYYXEQ42W2NXSQ", "Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "Action": "PUT", "Available Space": 798826333946}
2020-05-06T12:25:47.197Z INFO piecestore upload canceled {"Piece ID": "MM5SGBQ6S5W34FSKZZZKT4W3EBUQ5ALACY2DA4IYYXEQ42W2NXSQ", "Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "Action": "PUT"}
2020-05-06T12:25:47.901Z INFO piecestore upload started {"Piece ID": "XTZQBMH2NIKMITWZES7TRDVSNPI3IWJX7F4UTQJW5V4GIA7ORTVA", "Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "Action": "PUT", "Available Space": 798824014074}
2020-05-06T12:25:51.486Z INFO piecestore upload canceled {"Piece ID": "XTZQBMH2NIKMITWZES7TRDVSNPI3IWJX7F4UTQJW5V4GIA7ORTVA", "Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "Action": "PUT"}
2020-05-06T12:26:38.716Z INFO piecestore upload started {"Piece ID": "BYTCENTLG4FUYU5CKPW7ST6AZGFJ4PHYLUGDU5FCF74HN66HT33Q", "Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "Action": "PUT", "Available Space": 798821694202}
2020-05-06T12:26:40.814Z INFO piecestore upload canceled {"Piece ID": "BYTCENTLG4FUYU5CKPW7ST6AZGFJ4PHYLUGDU5FCF74HN66HT33Q", "Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "Action": "PUT"}
2020-05-06T12:26:48.184Z INFO piecestore upload started {"Piece ID": "Z6BA5EBP4OZFQNT2MFSG7H7FNBHKYVIPLMWL6D6BLRBJKBQER3CQ", "Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "Action": "PUT", "Available Space": 798819374330}
2020-05-06T12:26:51.059Z INFO piecestore upload started {"Piece ID": "A5E6LLJNSSDTGDVSJTZEEB5L7DXPMK56TOHUZJXQYXSAN4US6XCA", "Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "Action": "PUT", "Available Space": 798819374330}
2020-05-06T12:26:51.556Z INFO piecestore upload canceled {"Piece ID": "Z6BA5EBP4OZFQNT2MFSG7H7FNBHKYVIPLMWL6D6BLRBJKBQER3CQ", "Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "Action": "PUT"}
2020-05-06T12:26:52.124Z INFO piecestore upload canceled {"Piece ID": "A5E6LLJNSSDTGDVSJTZEEB5L7DXPMK56TOHUZJXQYXSAN4US6XCA", "Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "Action": "PUT"}
2020-05-06T12:27:44.436Z INFO orders.118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW sending {"count": 5}
2020-05-06T12:27:44.437Z INFO orders.12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB sending {"count": 96}
2020-05-06T12:27:44.669Z INFO orders.118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW finished
2020-05-06T12:27:44.763Z INFO orders.12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB finished
2020-05-06T12:28:19.956Z INFO piecestore upload started {"Piece ID": "IQKU7PQ4LOZ3U3UWVAFPJCA46NOJWSE7WA6UXZM5MUSQGBUUTMTA", "Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "Action": "PUT", "Available Space": 798814734586}
2020-05-06T12:28:21.722Z INFO piecestore upload canceled {"Piece ID": "IQKU7PQ4LOZ3U3UWVAFPJCA46NOJWSE7WA6UXZM5MUSQGBUUTMTA", "Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "Action": "PUT"}
2020-05-06T12:28:49.084Z INFO piecestore upload started {"Piece ID": "J6PJSWMEHPPLAQKLBNWRPTLLVZ7WQWJK4DNCXZSVQK2F2IT32Y4Q", "Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "Action": "PUT", "Available Space": 798812414714}
2020-05-06T12:28:49.968Z INFO piecestore upload started {"Piece ID": "INUBPWYAYPJOMSWAL53E67EN6OQAZWTRBSIV2HIKLBXU5D2BLNKA", "Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "Action": "PUT", "Available Space": 798812414714}
2020-05-06T12:28:51.882Z INFO piecestore upload canceled {"Piece ID": "J6PJSWMEHPPLAQKLBNWRPTLLVZ7WQWJK4DNCXZSVQK2F2IT32Y4Q", "Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "Action": "PUT"}
2020-05-06T12:28:52.574Z INFO piecestore upload canceled {"Piece ID": "INUBPWYAYPJOMSWAL53E67EN6OQAZWTRBSIV2HIKLBXU5D2BLNKA", "Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "Action": "PUT"}
2020-05-06T12:30:01.668Z INFO piecestore upload started {"Piece ID": "X56CY66GCNWII7ZXKSAV4LP6B4LULYS3FD4BGZVRLWNZP6MZ7ZKQ", "Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "Action": "PUT", "Available Space": 798807774970}
2020-05-06T12:30:03.687Z INFO piecestore upload started {"Piece ID": "JKMLN4JZGCAP2OJBBEPKR5LAX36GGFACLCGNLPGJ2P3ZDEQYWAFQ", "Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "Action": "PUT", "Available Space": 798807774970}
2020-05-06T12:30:04.137Z INFO piecestore upload canceled {"Piece ID": "X56CY66GCNWII7ZXKSAV4LP6B4LULYS3FD4BGZVRLWNZP6MZ7ZKQ", "Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "Action": "PUT"}
2020-05-06T12:30:10.673Z INFO piecestore upload canceled {"Piece ID": "JKMLN4JZGCAP2OJBBEPKR5LAX36GGFACLCGNLPGJ2P3ZDEQYWAFQ", "Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "Action": "PUT"}
2020-05-06T12:30:26.488Z INFO piecestore upload started {"Piece ID": "ZLMYRQJAOXLLOIIRG373P2K3OJPHGNCNY6MVWDECUV2F2E4FHY7Q", "Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "Action": "PUT", "Available Space": 798803135226}
2020-05-06T12:30:30.007Z INFO piecestore upload canceled {"Piece ID": "ZLMYRQJAOXLLOIIRG373P2K3OJPHGNCNY6MVWDECUV2F2E4FHY7Q", "Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "Action": "PUT"}
2020-05-06T12:30:50.067Z INFO piecestore download started {"Piece ID": "X56CY66GCNWII7ZXKSAV4LP6B4LULYS3FD4BGZVRLWNZP6MZ7ZKQ", "Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "Action": "GET"}
2020-05-06T12:30:54.694Z INFO piecestore downloaded {"Piece ID": "X56CY66GCNWII7ZXKSAV4LP6B4LULYS3FD4BGZVRLWNZP6MZ7ZKQ", "Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "Action": "GET"}
2020-05-06T12:30:58.074Z INFO piecestore upload started {"Piece ID": "BVLDI3VXC2WONARCBPWXC34QEKX7ZWFK7U2S3RNAFOQWFXNQWXHQ", "Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "Action": "PUT", "Available Space": 798800815354}
2020-05-06T12:31:04.792Z INFO piecestore upload canceled {"Piece ID": "BVLDI3VXC2WONARCBPWXC34QEKX7ZWFK7U2S3RNAFOQWFXNQWXHQ", "Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "Action": "PUT"}
[root@localhost ~]#
Your node is DQed on 4 satellites. Check your log for audit failures. Search for download failed
and GET_AUDIT
PS: You won’t find anything if your log isn’t redirected to a file. Every time you restart it deletes the log
But general idea is - why? That is fresh auth token
Show your docker run command and remove any personal info.
Also show result of
df -h
[root@localhost ~]# egrep -v "WALL|EM|ADDR" storj.sh
docker run -d --restart unless-stopped -p 28967:28967 \
-p 127.0.0.1:14002:14002 \
-e STORAGE="845GB" \
-e BANDWIDTH="60TB" \
--mount type=bind,source="/root/.local/share/storj/identity/storagenode/",destination=/app/identity \
--mount type=bind,source="/storj",destination=/app/config \
--name storagenode storjlabs/storagenode:beta
[root@localhost ~]# df -h
Filesystem Size Used Avail Use% Mounted on
devtmpfs 479M 0 479M 0% /dev
tmpfs 491M 0 491M 0% /dev/shm
tmpfs 491M 7.1M 484M 2% /run
tmpfs 491M 0 491M 0% /sys/fs/cgroup
/dev/mapper/centos-root 50G 3.8G 47G 8% /
/dev/mapper/centos-home 180G 34M 180G 1% /home
/dev/sdb1 932G 1.4G 930G 1% /storj
/dev/sda1 1014M 199M 816M 20% /boot
tmpfs 99M 0 99M 0% /run/user/0
overlay 50G 3.8G 47G 8% /var/lib/docker/overlay2/d1e160930199acfe5c4ec5889b270e5ff839fe3e55cda1ddcdbaecab7644bd4d/merged
overlay 50G 3.8G 47G 8% /var/lib/docker/overlay2/14351afad8c078a5c26fb8d5e1ba70f10f223796e3801e348a570c72d88546e2/merged
[root@localhost ~]#
I had to recreate a sno after a partition got damaged after only 20 days of activity. I requested a new token and redid the correct procedure with a new identity and cleaned everything. Now I risk that I disqualify this new node in your opinion?
Did you follow static mount point ? This is shown here
Did you figure out why your partition got damaged ?
We all learn from our mistakes but the important part here is learning from it. If you make sure your previous mistake won’t be repeated then you are good.
You have to make sure you aren’t failing audits. Currently DQ due to low uptime is not implemented so your node probably lost data during partition loss and therefore failed audits.
Use monitoring options like uptimerobot.com to get email notification when your node is offline. Check logs for download failed
and 'GET_AUDIT` to make sure you aren’t failing audits.
The disk was very old. Now i bought a new HP Proliant DL380E G8 with 14 bay with 14 hgst 3TB SAS for new SNO and P822 Controller with 2GB Cache. Now the errors are egual to zero or i hope. One question: I requested the token with the same email as the previous one. Maybe here I made the mistake. Quite right? Do I have to request it with a new email? Because it’s been 24 hours that it’s online and it’s not downloading anything. He basically downloaded 5GB in total between all the satellites. And from Saltlake = 0.
