Hello, I had to reinstall my server where my SNO is running on. So I lost all Storj Data but started with the same identity.
How bad is this? Will my node be disqualified?
How do I check my getting prozess? I were 25% done over all Satellites but I am no longer sure how it is now. The script from the forum reports:
Yes I did and I corrected it. I guess it will not happen again.
Still traffic is coming in way faster than in the beginning. Sure I have to start new? What will happen to my payments?
you might be able to gracefully exit once it is implemented if the downtime disqualification is still disabled at that point. But that’s just a tiny piece of hope for your hold back payment.
I thought it could repair your data and use your funds that are being held to repair the data that is missing depending on how much data you actually lost. I mean probably not an entire loss but if you did loose some data it could be repaired.
