So I installed the storage node without issue but was not aware you couldn’t add storage later.
I ran the installer again to remove the program & deleted the storj folder in appdata/roaming & the program folder.
I then tried to reinstall using the same files, when the node came online I noticed the suspension & audit had gone from 100% to 0%
I assumed I needed a fresh identity key so I generated a new one & started again.
Deleted both folders etc.
This time after installation I can see a new node id # but I’m getting the same 0% in suspension & audit.
Hello, @Dirty_Underpants i also faced a simmilar issue and i understood that the identity is attached to the data. So if you wanted to use the old data you should keep the old identity, and if you will use a new one, you should also wipe out the data from your disk. (And that means clean the folder that you have specified to be used by storj)
