No integrity, but earlier the size was estimated, now the full hashtbl is scanned for precise size calculation. (thanks to Jeff for the info)
It’s possible that you have some problem with hashtbl, and earlier implementation didn’t read that part.
I rebuilding them on both nodes, i hope this will help.
I recreated hashtbl, got new file, it is 2x of old file.
do i need to copy it instead of old file?
do i need to change name like was old one?
update: just changed with new file, and node working with 1.141.2 version, and event looks more or less accurate stats.
Filename doesn’t matter. You can just delete old file and move new one to folder.
Hi! have the same issue after updating to 147.4
could u kindly upload the exe file and put here the command for windows node?
downgrading back is not an option anymore…
here is instructions how to make write-hashtbl.exe on windows it work
Unrecoverable error - Node Operators / troubleshooting - Storj Community Forum (official)
to run it, copy it to disk you want to repair
in cmd, make cd /d disk name where you have file
and run it in this cmd like
write-hashtbl.exe D:\hahstore\sattelite map\s0
this link depens on what sattelite you haveproblem in waht map s0 or s1 they hash their own hashtbl folders
