Removing a disqualified satellite from node
This node has been disqualified from EU1 and I want to remove EU1 from the node so it doesn’t come up at all. I’m in
Australia and only made 19c from this satellite in July so hardly worth trashing the whole node. I’m too far away to ever make any money off it.
Can be done in config.yaml with something like:
storage2.trust.exclusions: "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs@ eu1.storj.io:7777"
I used the docker command line option to forget untrusted satellite.
How To Forget Untrusted Satellites - Node Operators / FAQ - Storj Community Forum (official)
I used docker command, had to put /bin in the path but it worked well. Now the screen actually looks better being more compact. As there is now only 3 satellites competing for cpu and disk time, I may get a little bit extra on the remaining 3.
