It returns 2 instances, the second with “Bad message”
How can I do it?
How can I do it?
Please, post paths to your instances and we will try to figure out a right one
Here it is
/home/jubau/0storjnode/storage/info.db find:/home/jubau/0storjnode/storage/blobs/v4weeab67sbgvnbwd5z7tweqsqqun7qox2agpbxy44mqqaaaaaaa/4l’: Bad message
Please, show the output of the command
docker inspect storagenode -f '{{ .Mounts }}'
Here we are
[{bind /home/jubau/0storjnode /app/config true rprivate} {bind /home/jubau/storj/storagenode_keys /app/identity true rprivate} {volume 5f6f3d117affbe0a1cb89badb61ba73cea29b18391589c4106badb9ce3a49fe9 /var/lib/docker/volumes/5f6f3d117affbe0a1cb89badb61ba73cea29b18391589c4106badb9ce3a49fe9/_data /root/.local/share/storj/storagenode local true }]
You doesn’t have other copies of the info.db.
Have you replaced the -v options in your docker run command with the --mount?
Please, show the output of the command:
df -h
and
cat /etc/fstab
Here is the output:
UUID=8cac60dc-c714-11e8-a67a-b870f4913702 / ext4 defaults 0 0
/swap.img none swap sw 0 0
I have already done it!
