Hi everyone,
I recently got this error message in my node rpc: dial tcp 127.0.0.1:7778: connect: connection refused
I tried restarting Docker and removing the image but didn’t work.
See logs below:
2022-05-03T12:14:59.446575700Z 12550K .......... .......... .......... .......... .......... 87% 19.7M 0s
2022-05-03T12:14:59.449096706Z 12600K .......... .......... .......... .......... .......... 87% 18.0M 0s
2022-05-03T12:14:59.451639840Z 12650K .......... .......... .......... .......... .......... 88% 19.5M 0s
2022-05-03T12:14:59.454152771Z 12700K .......... .......... .......... .......... .......... 88% 19.6M 0s
2022-05-03T12:14:59.457836262Z 12750K .......... .......... .......... .......... .......... 88% 18.8M 0s
2022-05-03T12:14:59.460138973Z 12800K .......... .......... .......... .......... .......... 89% 14.4M 0s
2022-05-03T12:14:59.463168194Z 12850K .......... .......... .......... .......... .......... 89% 18.7M 0s
2022-05-03T12:14:59.465395555Z 12900K .......... .......... .......... .......... .......... 89% 18.4M 0s
2022-05-03T12:14:59.468056540Z 12950K .......... .......... .......... .......... .......... 90% 19.4M 0s
2022-05-03T12:14:59.470533824Z 13000K .......... .......... .......... .......... .......... 90% 18.6M 0s
2022-05-03T12:14:59.473076884Z 13050K .......... .......... .......... .......... .......... 90% 19.2M 0s
2022-05-03T12:14:59.475682240Z 13100K .......... .......... .......... .......... .......... 91% 18.9M 0s
2022-05-03T12:14:59.478937791Z 13150K .......... .......... .......... .......... .......... 91% 19.5M 0s
2022-05-03T12:14:59.481403353Z 13200K .......... .......... .......... .......... .......... 92% 15.1M 0s
2022-05-03T12:14:59.483933858Z 13250K .......... .......... .......... .......... .......... 92% 19.4M 0s
2022-05-03T12:14:59.486512974Z 13300K .......... .......... .......... .......... .......... 92% 19.1M 0s
2022-05-03T12:14:59.489070163Z 13350K .......... .......... .......... .......... .......... 93% 19.9M 0s
2022-05-03T12:14:59.491406875Z 13400K .......... .......... .......... .......... .......... 93% 19.6M 0s
2022-05-03T12:14:59.493737864Z 13450K .......... .......... .......... .......... .......... 93% 20.9M 0s
2022-05-03T12:14:59.496195240Z 13500K .......... .......... .......... .......... .......... 94% 19.9M 0s
2022-05-03T12:14:59.499211943Z 13550K .......... .......... .......... .......... .......... 94% 20.7M 0s
2022-05-03T12:14:59.501520802Z 13600K .......... .......... .......... .......... .......... 94% 16.6M 0s
2022-05-03T12:14:59.503895606Z 13650K .......... .......... .......... .......... .......... 95% 20.4M 0s
2022-05-03T12:14:59.506359575Z 13700K .......... .......... .......... .......... .......... 95% 20.7M 0s
2022-05-03T12:14:59.508860469Z 13750K .......... .......... .......... .......... .......... 95% 19.8M 0s
2022-05-03T12:14:59.511205310Z 13800K .......... .......... .......... .......... .......... 96% 19.7M 0s
2022-05-03T12:14:59.513673556Z 13850K .......... .......... .......... .......... .......... 96% 19.6M 0s
2022-05-03T12:14:59.516136840Z 13900K .......... .......... .......... .......... .......... 96% 20.5M 0s
2022-05-03T12:14:59.519130969Z 13950K .......... .......... .......... .......... .......... 97% 20.5M 0s
2022-05-03T12:14:59.521472828Z 14000K .......... .......... .......... .......... .......... 97% 16.5M 0s
2022-05-03T12:14:59.523820854Z 14050K .......... .......... .......... .......... .......... 97% 20.6M 0s
2022-05-03T12:14:59.526178102Z 14100K .......... .......... .......... .......... .......... 98% 20.6M 0s
2022-05-03T12:14:59.528643997Z 14150K .......... .......... .......... .......... .......... 98% 20.8M 0s
2022-05-03T12:14:59.530995560Z 14200K .......... .......... .......... .......... .......... 98% 19.6M 0s
2022-05-03T12:14:59.533335993Z 14250K .......... .......... .......... .......... .......... 99% 20.7M 0s
2022-05-03T12:14:59.535738888Z 14300K .......... .......... .......... .......... .......... 99% 21.0M 0s
2022-05-03T12:14:59.538255949Z 14350K .......... .......... .......... .......... .......... 99% 20.8M 0s
2022-05-03T12:14:59.538538075Z 14400K 100% 2.55M=0.8s
2022-05-03T12:14:59.538562686Z
2022-05-03T12:14:59.538761313Z 2022-05-03 12:14:59 (16.6 MB/s) - '/tmp/storagenode.zip' saved [14746241/14746241]
2022-05-03T12:14:59.538787387Z
2022-05-03T12:15:00.804762834Z 2022-05-03 12:15:00,804 CRIT Supervisor is running as root. Privileges were not dropped because no user is specified in the config file. If you intend to run as root, you can set user=root in the config file to avoid this message.
2022-05-03T12:15:00.833364124Z 2022-05-03 12:15:00,832 INFO RPC interface 'supervisor' initialized
2022-05-03T12:15:00.833544381Z 2022-05-03 12:15:00,833 CRIT Server 'inet_http_server' running without any HTTP authentication checking
2022-05-03T12:15:00.834432759Z 2022-05-03 12:15:00,834 INFO supervisord started with pid 1
2022-05-03T12:15:01.843671606Z 2022-05-03 12:15:01,841 INFO spawned: 'processes' with pid 55
2022-05-03T12:15:01.852909714Z 2022-05-03 12:15:01,851 INFO spawned: 'storagenode' with pid 56
2022-05-03T12:15:01.858895158Z 2022-05-03 12:15:01,857 INFO spawned: 'storagenode-updater' with pid 57
2022-05-03T12:15:01.863367658Z 2022-05-03 12:15:01,862 INFO exited: processes (exit status 0; not expected)
2022-05-03T12:15:01.904093135Z 2022-05-03T12:15:01.903Z INFO Running on version {"Process": "storagenode-updater", "Service": "storagenode-updater", "Version": "v1.53.1"}
2022-05-03T12:15:01.904994716Z 2022-05-03T12:15:01.904Z INFO Downloading versions. {"Process": "storagenode-updater", "Server Address": "https://version.storj.io"}
2022-05-03T12:15:01.987283529Z 2022-05-03T12:15:01.986Z INFO Operator email {"Process": "storagenode", "Address": "eduardo.sequeira.hernandez@gmail.com"}
2022-05-03T12:15:01.987913502Z 2022-05-03T12:15:01.986Z INFO Operator wallet {"Process": "storagenode", "Address": "0x290Eb454a283048ae0378f82bca20266C52eeB0e"}
2022-05-03T12:15:02.008282547Z Error: Error starting master database on storagenode: group:
2022-05-03T12:15:02.008381027Z --- stat config/storage/blobs: no such file or directory
2022-05-03T12:15:02.008408434Z --- stat config/storage/temp: no such file or directory
2022-05-03T12:15:02.008433045Z --- stat config/storage/garbage: no such file or directory
2022-05-03T12:15:02.008456748Z --- stat config/storage/trash: no such file or directory
2022-05-03T12:15:02.012350497Z 2022-05-03 12:15:02,011 INFO exited: storagenode (exit status 1; not expected)
2022-05-03T12:15:02.117521352Z 2022-05-03T12:15:02.116Z INFO Current binary version {"Process": "storagenode-updater", "Service": "storagenode", "Version": "v1.53.1"}
2022-05-03T12:15:02.117726423Z 2022-05-03T12:15:02.116Z INFO Version is up to date {"Process": "storagenode-updater", "Service": "storagenode"}
2022-05-03T12:15:02.146670956Z 2022-05-03T12:15:02.145Z INFO Current binary version {"Process": "storagenode-updater", "Service": "storagenode-updater", "Version": "v1.53.1"}
2022-05-03T12:15:02.146760288Z 2022-05-03T12:15:02.146Z INFO Version is up to date {"Process": "storagenode-updater", "Service": "storagenode-updater"}
2022-05-03T12:15:03.156053320Z 2022-05-03 12:15:03,154 INFO spawned: 'processes' with pid 88
2022-05-03T12:15:03.165170357Z 2022-05-03 12:15:03,164 INFO spawned: 'storagenode' with pid 89
2022-05-03T12:15:03.165728332Z 2022-05-03 12:15:03,165 INFO success: storagenode-updater entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2022-05-03T12:15:03.174590946Z 2022-05-03 12:15:03,174 INFO exited: processes (exit status 0; not expected)
2022-05-03T12:15:03.290283573Z 2022-05-03T12:15:03.289Z INFO Operator email {"Process": "storagenode", "Address": "eduardo.sequeira.hernandez@gmail.com"}
2022-05-03T12:15:03.290780327Z 2022-05-03T12:15:03.289Z INFO Operator wallet {"Process": "storagenode", "Address": "0x290Eb454a283048ae0378f82bca20266C52eeB0e"}
2022-05-03T12:15:03.293278870Z Error: Error starting master database on storagenode: group:
2022-05-03T12:15:03.293353092Z --- stat config/storage/blobs: no such file or directory
2022-05-03T12:15:03.293374091Z --- stat config/storage/temp: no such file or directory
2022-05-03T12:15:03.293393610Z --- stat config/storage/garbage: no such file or directory
2022-05-03T12:15:03.293412776Z --- stat config/storage/trash: no such file or directory
2022-05-03T12:15:03.297186063Z 2022-05-03 12:15:03,296 INFO exited: storagenode (exit status 1; not expected)
2022-05-03T12:15:05.308252901Z 2022-05-03 12:15:05,306 INFO spawned: 'processes' with pid 98
2022-05-03T12:15:05.317270719Z 2022-05-03 12:15:05,316 INFO spawned: 'storagenode' with pid 99
2022-05-03T12:15:05.326857215Z 2022-05-03 12:15:05,326 INFO exited: processes (exit status 0; not expected)
2022-05-03T12:15:05.442013226Z 2022-05-03T12:15:05.441Z INFO Operator email {"Process": "storagenode", "Address": "eduardo.sequeira.hernandez@gmail.com"}
2022-05-03T12:15:05.442451628Z 2022-05-03T12:15:05.441Z INFO Operator wallet {"Process": "storagenode", "Address": "0x290Eb454a283048ae0378f82bca20266C52eeB0e"}
2022-05-03T12:15:05.444771674Z Error: Error starting master database on storagenode: group:
2022-05-03T12:15:05.444865044Z --- stat config/storage/blobs: no such file or directory
2022-05-03T12:15:05.444887617Z --- stat config/storage/temp: no such file or directory
2022-05-03T12:15:05.444908580Z --- stat config/storage/garbage: no such file or directory
2022-05-03T12:15:05.444928691Z --- stat config/storage/trash: no such file or directory
2022-05-03T12:15:05.448321224Z 2022-05-03 12:15:05,447 INFO exited: storagenode (exit status 1; not expected)
2022-05-03T12:15:08.460906961Z 2022-05-03 12:15:08,459 INFO spawned: 'processes' with pid 108
2022-05-03T12:15:08.471751909Z 2022-05-03 12:15:08,470 INFO spawned: 'storagenode' with pid 109
2022-05-03T12:15:08.481290149Z 2022-05-03 12:15:08,480 INFO exited: processes (exit status 0; not expected)
2022-05-03T12:15:08.482332341Z 2022-05-03 12:15:08,481 INFO gave up: processes entered FATAL state, too many start retries too quickly
2022-05-03T12:15:08.596463510Z 2022-05-03T12:15:08.595Z INFO Operator email {"Process": "storagenode", "Address": "eduardo.sequeira.hernandez@gmail.com"}
2022-05-03T12:15:08.596867783Z 2022-05-03T12:15:08.596Z INFO Operator wallet {"Process": "storagenode", "Address": "0x290Eb454a283048ae0378f82bca20266C52eeB0e"}
2022-05-03T12:15:08.599415383Z Error: Error starting master database on storagenode: group:
2022-05-03T12:15:08.599495845Z --- stat config/storage/blobs: no such file or directory
2022-05-03T12:15:08.599516845Z --- stat config/storage/temp: no such file or directory
2022-05-03T12:15:08.599536271Z --- stat config/storage/garbage: no such file or directory
2022-05-03T12:15:08.599555104Z --- stat config/storage/trash: no such file or directory
2022-05-03T12:15:08.603111674Z 2022-05-03 12:15:08,602 INFO exited: storagenode (exit status 1; not expected)
2022-05-03T12:15:09.605434957Z 2022-05-03 12:15:09,604 INFO gave up: storagenode entered FATAL state, too many start retries too quickly
Does anybody has an idea what is going on?
Thanks
Edu
