Hi, was wondering if there’s the option to check if all is good before actually running a node in PROD environment. Thanks!
Yes. storj-sim. But it’s not makes any sense for Storage Node Operators - it’s automatically run 10 storagenodes and there’s nothing to test by SNO.
If you mean your hardware or OS, then there is only one method - just run it and see how it is going
If something goes wrong it’s no problem, create a new identity and start over with new knowledge
