I’m working through the S3 Uplink documentation. And I am at the step “Configure using an Access Grant” and it says to use this command…
./uplink share sj://site
When I do this, I get an error that says, “Invalid Access Grant Format” and I am using the latest binaries as of today.
I went into the Gatewat yaml config, and found the access string, and added a command so it was like this…
./uplink share sj://site --access
And that worked. But I’m not sure if what I did was right, or even necessary. Has something changed and obtaining an access grant via the uplink is no longer necessary? Or should I be getting this access string from somewhere else? Confused. I ran through this a couple weeks back with older binaries and this error didn’t happen in the uplink, so I realize something has changed in this process. (And our documentation is wrong)
