Script for Audits stat by satellites - only overall audits
Could you elaborate a little more?
What is error?
The script is no longer working?
It only shows the ID for the satellites but no audit stats.
Is there a way to fix that?
You can have a look at this post:
Hello,
I’ve got a different result as I expected, is that normal ?
“12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo”
“auditScore”: 1,
“suspensionScore”: 1,
“onlineScore”: 1,
“satelliteName”: “us2.storj.io:7777
“1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”
“auditScore”: 1,
“onlineScore”: 1,
“satelliteName”: “saltlake.tardigrade.io:7777
“121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”
“auditScore”: 1,
“onlineScore”: 1,
“satelliteName”: “ap1.storj.io:7777
“12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”
“auditScore”: 1,
“onlineScore”: 1,
“satelliteName”: “us1.storj.io:7777
“12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”
“auditScore”: 1,
“onlineScore”: 1,
“satelliteName”: “eu1.storj.io:7777
“12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB”
“auditScore”: 1,
“onlineScore”: 1,
“satelliteName”: “europe-north-1.tardigrade.io:7777
Hi @Washu,
This thread is outdated and the API has changed. The output you posted is correct for the current API. You could try this thread instead if you have Windows - How to check vetting state from API (PowerShell)
