Second node won't start
I’m trying to setup the second node on my raspberry.
I’ve generated a second identity and start the node with this
-p 28968:28967
-p 127.0.0.1:14003:14002
-e WALLET=“xxxxxxxxxxx”
-e EMAIL="xxxxxxx@gmail.com"
-e ADDRESS=“xxxxxxx.eu:28968”
-e STORAGE=“1TB”
–mount type=bind,source=“/media/maxtor/storagenode2/identity”,destination=/app/identity
–mount type=bind,source=“/media/maxtor/storagenode2/data”,destination=/app/config
–name storagenode2 storjlabs/storagenode:latest
The node keep restarting and all I get from the log is this
$ docker logs -f --tail 100 storagenode2
Error: sync /app/config/config.yaml500872744: structure needs cleaning
Error: sync /app/config/config.yaml336711568: structure needs cleaning
Error: sync /app/config/config.yaml607011623: structure needs cleaning
Error: sync /app/config/config.yaml143781070: structure needs cleaning
The data directory is empty, what I’m missing?
Please, show results of this command:
df -H
sudo grep "/media/maxtor/storagenode2" /etc/fstab
$ df -H
File system     Dim. Usati Dispon. Uso% Montato su
/dev/root       236G   56G    168G  25% /
devtmpfs        1,9G     0    1,9G   0% /dev
tmpfs           2,1G  8,2k    2,1G   1% /dev/shm
tmpfs           2,1G  203M    1,9G  11% /run
tmpfs           5,3M  4,1k    5,3M   1% /run/lock
tmpfs           2,1G     0    2,1G   0% /sys/fs/cgroup
/dev/mmcblk0p1  265M   56M    209M  22% /boot
tmpfs           402M     0    402M   0% /run/user/1001
/dev/sdc1       4,0T  3,2T    621G  84% /media/raspihdd
/dev/sda1       2,0T  476G    1,4T  26% /media/maxtor
$ cat /etc/fstab
proc                                           /proc            proc    defaults                   0 0
PARTUUID=6c586e13-01                           /boot            vfat    defaults                   0 2
PARTUUID=fec687e2-633a-a048-96a9-cf368b9f6927  /                ext4    defaults,noatime           0 1
PARTUUID=2d9512f2-01e7-8547-9b29-7ff09aef056b  /media/raspihdd  ext4    relatime,errors=remount-ro 0 1
PARTUUID=6815c43c-64bd-f447-978b-0c7299eb385c  /media/maxtor    ext4    relatime,errors=remount-ro 0 1
The error “structure needs cleaning” usual mean that filesystem is corrupted and need to be fixed with fsck.
The fsck should be performed on unmounted disk. So, you need stop and remove the container, unmount the disk and run fsck:
docker stop -t 300 storagenode2
docker rm storagenode2
sudo umount /media/maxtor
fsck /dev/sda1
When filesystem will be fixed, your can try to mount back and run the storagenode2
Thank’s for the help!
