i fired up a secondary node today
-15T16:16:26.778Z INFO Configuration loaded from: /app/config/config.yaml
2020-04-15T16:16:27.013Z INFO Operator email: tan@tan.com
2020-04-15T16:16:27.013Z INFO operator wallet: 0x84E1F59F22a04f4d248c8c8E701377a4B88928BA
2020-04-15T16:16:27.597Z INFO version running on version v1.1.1
2020-04-15T16:16:27.723Z INFO db.migration Database Version {“version”: 33}
2020-04-15T16:16:28.337Z INFO preflight:localtime start checking local system clock with trusted satellites’ system clock.
2020-04-15T16:16:29.094Z INFO preflight:localtime local system clock is in sync with trusted satellites’ system clock.
2020-04-15T16:16:29.094Z INFO bandwidth Performing bandwidth usage rollups
2020-04-15T16:16:29.095Z INFO trust Scheduling next refresh {“after”: “3h23m38.700221953s”}
2020-04-15T16:16:29.095Z INFO Node started
2020-04-15T16:16:29.095Z INFO Public server started on [::]:28968
2020-04-15T16:16:29.095Z INFO Private server started on 127.0.0.1:7778
2020-04-15T16:16:29.341Z INFO version running on version v1.1.1
am using port 28968 on this one i manually changed the port on the config.yaml to use 28968 and i also changed 28967 back and ford but i got the results
dont know if am missing something
