Setup 2. Node on raspberry fails
Hello Guys.
I just run last week my first Node on my raspberry online :sweat_smile:
I want to connect 3 further HDD to my raspberry 3b, do you think that this is too much for the raspberry? My connection: 50Mbit/s Up and 1000Mbit/s Down.
On my first 48hr i had 12GB Traffic, seems a bit low…
I just tried to run 2nd Node on the same raspberry but failed.
I created a new Key and Authentication and followed the steps on the storji-documentation. The Container is only running for seconds on the dashboard, then restart and after 5min exit.
I opened for the first Node the port 28967 TCP and on the scan he’s open.
For the 2nd Node i opened 28967 but the scan tell me that he’s still closed :sleepy:
Here are my settings:
sudo docker run -d --restart always --stop-timeout 300 \
-p 28968:28967 \
-p 127.0.0.1:14003:14003 \
-e WALLET="0x****************************" \
-e EMAIL="**************@gmail.com" \
-e ADDRESS="**************:28968" \
-e STORAGE="8TB" \
--memory=800m \
--log-opt max-size=50m \
--log-opt max-file=20 \
--mount type=bind,source="/mnt/storj2/Identity/storagenode",destination=/app/identity \
--mount type=bind,source="/mnt/storj2/Datenbank",destination=/app/config \
--name storagenode2 storjlabs/storagenode:latest
Maybe someone can help me? I had read that the port is only open when it is accessed… so maybe the first issue takes care of itself with the first issue?
Other Question: Do i need for every Node a new E-Wallet? That seem’s to be really stupid …
Thanks!
on your router, you need to port forward 28968 for second node.
that should be -p 127.0.0.1:14003:14002
Wallet address should be the same for all of your nodes.
E-mail address can be the same for all of your nodes.
I don’t export my logs out of docker, so I can’t comment on the
part of your run command.
Sorry, my mistake. i opened 28968 for the 2. Node.
Still the same after changing to 14003:14002 …
Hello,
What is in the logs?
Why you use docker run -d --restart always???
In documentation is…
docker run -d --restart unless-stopped
BTW if you have one public IP is better to run only 1 storagenode and after this node is 80-90% full start next node…
Because “i do the same as i did for the first Node”…
how i call the logs? After i send the command i wrote in the first Post:
"WARNING: Your kernel does not support memory limit capabilities or the cgroup is not mounted. Li mitation discarded.
1d88b1afe14e53b6d4c3096f375867ed738f9f18b37560f0e3163f7c6833da09
Setup the second node with https://documentation.storj.io/
Only nodes setup with documentation we can troubleshoot
There you can see how to check logs
https://documentation.storj.io/resources/faq/check-logs
I’d argue (and have done myself) to open up additional nodes if I have the hardware for it. My reasoning being to start the vetting process/held window on the nodes. This is done with the understanding that all nodes behind a /24 IP get logically viewed as a single node when the satellites are looking for nodes to take pieces for the purpose of geographic protection of the data.
I’m running an RPi3 with 3 drives (2G, 2G, 1G) attached to it. They’re all in one USB dock. No issues seen so far. Note I’ve omitted the --memory=800m from my docker run statements because the RPi3 only has 1GB of memory. Maybe this is where you’re having an issue?
Thats what i get evrytime:
2021-04-05T21:36:31.134Z ERROR contact:service ping satellite failed {“Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “attempts”: 11, “error”: “ping satellite error: check-in network error: failed to resolve IP from address: ******.ddnss.de:28967, err: lookup *******.ddnss.de on 10.124.0.10:53: server misbehaving”, “errorVerbose”: “ping satellite error: check-in network error: failed to resolve IP from address: *******.ddnss.de:28967, err: lookup ******.ddnss.de on 10.124.0.10:53: server misbehaving\n\tstorj(.)io/storj/storagenode/contact.(*Service).pingSatelliteOnce:138\n\tstorj(.)io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj(.)io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj(.)io/common/sync2.(*Cycle).Run:92\n\tstorj(.)io/common/sync2.(*Cycle).Start.func1:71\n\tgolang(.)org/x/sync/errgroup.(*Group).Go.func1:57”}
editet the links because i can only have 2 per post.
i fixed that now. gave only 200m for the 2.(only for testing) still doesnt working.
I get now only the state “offline”
Hello @elcoapon ,
Seems your DDNS address is mistyped. Please, check it in your first node. If this was logs from the second, please, make sure that you specified port 28968 in your -e ADDRESS option, because logs complaining on address with port 28967.
To check logs for the second node you need to use a name of the second node, i.e.
docker logs --tail 20 storagenode2
The --memory=800m option is to limit the RAM usage, it’s not a request. This option was needed in case if your memory usage can grow unlimited and Pi will hang. With this option the node will be killed instead.
