Hi @nickreserved,
From my understanding it’s not possible to share a directory to an https:// link, but if you use uplink with the --url to share a single file then it should generate a URL
Before ask the question, I read the first link you provide.
So, it seems that I want a path-based linkshare.
I run the command:
uplink share sj://AAA/BBB --public --readonly --not-after=none
I get the:
Sharing access to satellite abcdefg@eu1.storj.io:7777
Access gfedcba
The question remains the same (because first link you provide didn’t say something clear about this)
How can I give a https//??? link to my friends for the sharing content?
It is possible. Try the same command just with sj://bucket and you will share the entire bucket. If you open the link you should see the content of the bucket inside the browser. Just be careful with sharing it. It would be better to share on a folder level in order to minimize the potential damage.
I don’t think this has been implemented into the file browser. If you have a need for it please open a feature request. I don’t see a reason why it shouldn’t be possible. It is more a question of priorities.
