Should I be nervous or will it get online
if it would not fail - it should.
this is mean that the filewalker likely didn’t finish the calculation. You should enable the used-space-filewalker on start, disable the lazy mode and restart the node.
Each filewalker should successfully finish its job for each trusted satellite, then it will move the deleted data to the trash and update the usage in the databases and on the dashboard.
thx for the help one more
