Sorry guys, I can’t get it to work…
1st without wallet it doesnt start, error log says as before. !!! WALLET_ADDRESS must be set to an ERC20 wallet address
created directory: '/storj/share'
created directory: '/storj/log'
* starting daemon in foreground
* configuration written to /storj/config.json
{"level":"info","message":"attempting to start node with config at path /storj/config.json","timestamp":"2019-10-06T20:15:21.331Z"}
* starting node with config at /storj/config.json
{"level":"info","message":"got status query","timestamp":"2019-10-06T20:16:59.529Z"}
If I add a wallest the error I get is: failed to start node, reason: invalid directory: /volume1/storj/v2/data/ does not exist
So in my run command the storj is with a S not s…
As this is my normal v3 folder there as well, don’t want to change.
I’m traveling so could change it later to a lowercase folder / or any other suggestions?
Yeah so how I write it, it’s correct. I’ll see if i find a new folder where it’s all lowercase and move the data there. Maybe the dst= only transforms it to lowercase and then it’s not working even though input is uppercase.
