I get my node running using the .msi GUI installer and it works fine. I come home after work to check it and it is offline, so I uninstall and reinstall using the .msi GUI program again. The port is open 28967. It keeps disconnnecting for some reason. Any ideas?
My firewall for some reason arbitrarily stops programs from using their required ports then just as suddenly allows them. Microsoft must have bought the company ā¦ windows likes to restart when Iām not looking to update itself too.
