Hello!
I added yesterday a second node to my server after successfully filling in a first HDD.
I went through the process to create a new identity, added my auth token, and ran the following command:
sudo docker run -d --restart unless-stopped -p 28968:28967
-p 14003:14002
-e WALLET=“XXX”
-e EMAIL=“XXX”
-e ADDRESS=“XXX:28968”
-e BANDWIDTH=“20TB”
-e STORAGE=“7.0TB”
–mount type=bind,source="/home/XXX/.local/share/storj/identity/storagenode1/",destination=/app/identity
–mount type=bind,source="/storj1",destination=/app/config
–name storagenode1 storjlabs/storagenode:beta
Looking at the logs, I am seeing download errors such as the ones below:
2020-01-05T10:55:17.517Z INFO piecestore download started {“Piece ID”: “MHG5WVF6ILPMAHC75IYULPURBRLFK2PACZWGAP3YIQ7H7LQKOP4Q”, “Satellite ID”: “118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW”, “Action”: “GET”}
2020-01-05T10:55:29.033Z INFO piecestore download failed {“Piece ID”: “MHG5WVF6ILPMAHC75IYULPURBRLFK2PACZWGAP3YIQ7H7LQKOP4Q”, “Satellite ID”: “118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW”, “Action”: “GET”, “error”: “piecestore: piecestore protocol: write tcp 172.17.0.2:28967->116.203.252.13:49372: use of closed network connection”, “errorVerbose”: “piecestore: piecestore protocol: write tcp 172.17.0.2:28967->116.203.252.13:49372: use of closed network connection\n\tstorj.io/drpc/drpcstream.(*Stream).pollWrite:189\n\tstorj.io/drpc/drpcwire.SplitN:25\n\tstorj.io/drpc/drpcstream.(*Stream).RawWrite:233\n\tstorj.io/drpc/drpcstream.(*Stream).MsgSend:266\n\tstorj.io/storj/pkg/pb.(*drpcPiecestoreDownloadStream).Send:1166\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doDownload.func3:643\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2020-01-05T10:56:39.054Z INFO piecestore download started {“Piece ID”: “JHXMHCW3P4GM54555YBV4ULDWFKXPJ3WJMGCCPVATNIKHMLRFEHQ”, “Satellite ID”: “118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW”, “Action”: “GET”}
2020-01-05T10:56:43.664Z INFO piecestore download failed {“Piece ID”: “JHXMHCW3P4GM54555YBV4ULDWFKXPJ3WJMGCCPVATNIKHMLRFEHQ”, “Satellite ID”: “118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW”, “Action”: “GET”, “error”: “piecestore: piecestore protocol: context canceled”, “errorVerbose”: “piecestore: piecestore protocol: context canceled\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doDownload.func3:652\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
On the dashboard side, my node seems to be online, I get 100% audit checks on all Satellites, however uptime checks stand at 31.9% for all Satellites.
Is something going on that I should fix on my side?
Many thanks for your help
